Bronco II Ford Bronco II
engine timing
Old Dec 21, 2005 | 06:37 PM
bronocIInoob's Avatar
bronocIInoob
engine timing
ON my bronoc II a little while ago i mistook two sparkplugs wires and put them on the wrong cylinders a the engine ran like the timeing of an early muscle car i just had the exuast repaired and the muffler was off and i proposly switched the same wires again to see what it did and sounded like the power output seemed the same and the exuast was loader and sounded better then my friend challenger i would like to know what if any probelms will be the cuase of this ill cylinder timing if i did drive around like this for a while and if i did do damage now the engine did idle so it didnt seem to be way off wut will be the cuase of this
Old Dec 21, 2005 | 07:07 PM
bronocIInoob
also i found out somthing gay as far as i could see they dont make good cams, timing gears,or rockers for the 2.9 motor i have on my bII becuase it is emission controled computer system and it would fail insepction or something like that dose anyone know legal cams for 1986 and above bronco II's? cams lifters of gears please give me a link
Old Dec 21, 2005 | 08:11 PM
Ken00's Avatar
Ken00
Camcraft makes cams, you can make free floating rockers.
Old Dec 21, 2005 | 09:03 PM
bronocIInoob
like alot of other things this is another thing i am forgeting they dont make legal cams for the 2.9 becuase of emmisions so thats out as far as switching wires im puting the wires back as i knew they will affect the engine in a bad way altuogh it sounds so cool thanks anyway
