The cover is a separate piece. Two screws below and to the left and right of the steering wheel. Three screws on the front edge close to the windshield. Once they are out tap it upward right behind the steering wheel and in between the pods that hold the light switch and a/c heat controls. There are two plastic pins that fit into a slot tightly. That will separate the cover from the cluster.....
