02 F250 Overhead Console Gone Out - Page 20 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #286
Old 01-27-2017, 10:29 PM
infoseeker11 infoseeker11 is offline
infoseeker11 is starting off with a positive reputation.
This is a 2004 f350 overhead console (OTC). Just died last week. Same issue as this thread ... bad solder joints on the 640 resisters.
  #287
Old 02-28-2017, 02:29 AM
ronmo ronmo is offline
ronmo is starting off with a positive reputation.
Overhead console
Just bought a 03 7.3 F250 CC and no display. It looks like I have found my direction here! I hate pulling on those plastic pieces and it sounds like this piece really makes you think you are going to break something. I will be sure to repost after I have a look at mine.
Now to look for my fuel gauge reading below E...
Thanks and
Ron
  #288
Old 05-21-2017, 09:42 PM
Joshua Jacobs Joshua Jacobs is offline
Joshua Jacobs is starting off with a positive reputation.
Thanks
Quote:
Originally Posted by Miescha View Post
Here is the process to remove and repair the overhead console in your truck. Click on the red links for detailed photos.
First, you must remove the outer shell (colored to match the interior of your truck). There are five tension clips that hold the shell in place. Begin by pulling downward (I just use my fingers to prevent damage) on the front (toward windshield) of the shell. You must pull VERY hard - it feels like it will break, but has never happened to me, and I've done a few now.
Once the front two tension clips pop loose, you must release two "L" shaped tension clips that lock into the storage compartment. You can BARELY see the tips of the clips when looking inside the compartment. Use a flat head screwdriver or similar tool to push out on the clips until they release. I've also tried reaching above the outer shell to pull on these clips (rather than pushing from inside the storage compartment), but my hands are too big.
Once these two are released, there is one final tension clip on the rear that comes off fairly easily.
Next, you will see the black inner shell. First, unplug the wire harness on the passenger side of the unit. Next, you must again pull from the front (toward the windshield) with force to release two additional tension clips. Finally, tilt the unit downward to release the "L" bracket at the rear (the "L" shaped bracket slides into a hole in the roof - no pulling required).
Once you have the unit out, remove the circuit board from the inner shell by removing the three torx screws (I believe they are 8mm but I can't recall).
Once the circuit board is removed, locate the 7 chips on the circuit board behind the display. They are labeled 620 and 680. The two I most often find loose are the two in the center directly behind the display - but check them all. Once the loose chips are located, re-attach them using a soldering pen (DO NOT USE A SOLDERING GUN AS THEY ARE TOO HOT AND MAY DAMAGE THE CIRCUIT BOARD). If there is not sufficient solder already in place (often the case for me), add additional solder as needed.
Now test the display by plugging in just the board in your truck and turn the key. If all works, put the board back on the inner shell and then replace the inner shell and plug in the wire harness. Then snap the outer shell in place and enjoy!
Check out my gallery for additional photos. If you find the chips are not the problem and the board is actually dead, check out ebay or similar locations to find a better deal than the $500 the dealer wants. I've never had luck at scrap yards, but you might try those also. Finally, if you really can't find one, drop me a message and I'll see if I have any left from prior bulk purchases made prior to discovering the above repair procedure.
Let me know if you have additional questions and good luck!
You sir, are my personal hero for the day. Followed your steps and it works like a charm.
  #289
Old 05-21-2017, 09:48 PM
Foam
Quote:
Originally Posted by F3504ME View Post
Just added an update and wonder any thoughts on the foam question
I removed mine as well. I work with micro-computer repair folks and called a couple before I reinstalled the board. They said Chuck it, not needed and could cause issues down the road. Since they work on multi million dollar equipment in the Navy I chose to believe them.
  #290
Old 06-23-2017, 11:56 AM
Macerdaffi Macerdaffi is offline
Macerdaffi is starting off with a positive reputation.
permanent fix
I fixed this consol 4 times and then found ebay repair guy named Ruberg and had it fixed and shipped in less than a week for $22. Sweet.
  #291
Old 07-26-2017, 06:19 PM
Darrylcases Darrylcases is offline
Darrylcases is starting off with a positive reputation.
Parts to overhead console
Do you have any of the parts available? If so how can I get a hold of you to get a new circuit board?
  #292
Old 07-26-2017, 06:21 PM
Repair guy ebay
Do you have the contact information available? I'm having the same problem
do you have the contact information available? I'm having the same problem!
QUOTE=Macerdaffi;17280199]I fixed this consol 4 times and then found ebay repair guy named Ruberg and had it fixed and shipped in less than a week for $22. Sweet.[/QUOTE]
  #293
Old 07-26-2017, 07:14 PM
Big_John's Avatar
Big_John Big_John is offline
Big_John is starting off with a positive reputation.
Mine is on the way out there now.
Ford F150 F250 F350 Compass Temperature Overhead Console Display Repair Service
  #294
Old 08-16-2017, 10:19 PM
2003 F250 Lariat console update,
Because of everything I have read I was sure the problem was a bad circuit board, I never even looked for a fuse.
I had Dave Ruberg fix mine for $22 (Dave is super nice on the phone and fast service. It was back in the mail within 2 hours of delivery to him)
I got it back yesterday and put it back in last night and it is still dark.... SO NOW, I have looked in my manual and no fuse is mentioned for the overhead console. I have had the truck for almost 6 months and everything works, so DOES it have a fuse somewhere that I need to find?
I called Dave, he said to check it should have 6 wires on the top row and 4 on the bottom row.
My trucks plug has only has 5 on the top row and 4 on the bottom. (It sure looks to be factory..)
The circuit board has 6 pins on the top row and 4 on the bottom row,(two on each side with a gap in the center).
Anyone have theirs open to have a look and see If my truck is missing something...
Thank all
Ron
  #295
Old 01-21-2018, 08:51 AM
b7200 b7200 is offline
b7200 is gaining momentum as a positive member of FTE.b7200 is gaining momentum as a positive member of FTE.
Does anyone know if Dave Ruberg is still fixing these OH consoles. I searched on ebay without any luck. Mine is missing a chip.
Thanks
Phil
  #296
Old 01-21-2018, 08:55 AM
Big_John's Avatar
Quote:
Thanks
Phil
I believe this is who you are looking for.
https://www.ebay.com/itm/Ford-F150-F...614?rmvSB=true
  #297
Old 01-21-2018, 09:18 AM
Thanks Big John
Show your overhead consoles Airborne-F250 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-21-2017 04:26 AM
08' Overhead Console what's the clip thing for? CKetchum 1999 to 2016 Super Duty 4 01-27-2017 06:40 PM
2012 Overhead console madsonp 1999 to 2016 Super Duty 7 11-16-2016 02:25 PM
overhead console questions Matt Newby 1994.5 - 1997 7.3L Power Stroke Diesel 8 08-17-2016 09:22 PM
Overhead console Vinford 6.0L Power Stroke Diesel 5 01-12-2016 04:59 AM
Tags
01, 2003, 2004, 250, console, display, f250, f350, ford, overhead, problems, removal, remove, repair, roof
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
