T5 Tranny Conversion for 1950 Pickup
#32
Originally Posted by AXracer
The latest issue of Street Rodder has an article on adapting a different arm/handle to the T5 shifter.
Rod
#33
Originally Posted by 51ford fan
Yes thanks AXracer, I ran over to Borders Bookstore at lunch and picked up the last copy. I was a little disappointed though because I have read some other forums where they mention installing a 1" spacer between the shifter mounting flange and the trans to shorten the throw. I was hoping that would also be incorporated in that article because that Swan shifter handle would probably make the shifter arm travel as long as the stock unit. And I think possibly, without the stops the aftermarket shifters have built into them. That long extention might allow too much leverage to be exerted and lead to internal wear in the trans.
Rod
Rod
#34
#35
AXracer thanks for the information on the TPI Gauges they look like the answer to the problem and I like how easy they are to calibrate.
Also do you know who sells a short throw shifter kit for the T5 transmission.
Thanks Rod
Thanks Rod
#36
Poes
06-29-2015 08:17 AM
Tempole
06-27-2014 06:47 PM
Ford1950f1
11-20-2011 04:41 AM
JMS50F5COE
09-20-2010 03:19 AM
vjp8378
12-19-2005 09:04 PM
1950, adjusting, brakes, conversion, f3, flathead, ford, gears, how, instaaling, pickup, rearend, secondchancecharternet, swap, t5, transmission, truck
