Header Problem
Old Dec 21, 2005 | 09:17 PM
wideopen23's Avatar
wideopen23
Damn they are expensive, has anyone found them for the 460 for less than 450?
Old Dec 22, 2005 | 12:05 PM
ivanribic's Avatar
ivanribic
Go to BroncoGraveyard via this link and look down the page, a little below the L&L headers. You'll find a generic brand of fenderwell exit headers for the 460 for $355. What I don't like is they are not coated/finished. If you paint them with high-temp paint it's gonna start rusting in no time. If you get them ceramic coated you'll pay another $100-$150 for that. Anyway, here's the link: http://broncograveyard.com/bronco/c-99_460_swaps.htm
Old Dec 27, 2005 | 10:24 AM
gier-head's Avatar
gier-head
I have a 78 F-350 Custom 2wd 140" wheelbase w/400M 4 spd w/o AC ( I think that's all the specifics ). It's an old farm truck more or less. One stock exhaust manifold is cracked and exhaust is rusty. It also has the LH inside frame gas tank which causes problems it seems for dual exhaust. I suppose you have to run em down the RH side of the inside frame if you want to do that. Also..........from what I've researched, they don't make conventional aftermarket headers that will work with the 4spd linkage and such.
Good thread on these fenderwell exiting headers. Would this be a good option for me??? Any thoughts or suggestions would be much appreciated. I like to do things myself. And I know dual exhausts with the factory cast iron manifolds ( after I replace the cracked one ) would require professional help which wouldn't cost less than $200 probably.
Old Dec 27, 2005 | 11:31 AM
gier-head's Avatar
gier-head
Here's what I found so far for fenderwell exiting headers:
Broncograveyard site: Hedman #2055 $195.00 ( do not mention F-350 application )
Jeg's site: Hedman #500--089360 $191.99
Will either of the work? Both applications mention 4WD application only. My truck is 2WD F-350 with a 4 speed ( granny low ).
Thanks.
Old Dec 27, 2005 | 05:14 PM
74 F100 351m's Avatar
74 F100 351m
[IMG][/IMG] I made my own.
Old Dec 28, 2005 | 12:38 AM
BigBody's Avatar
BigBody
Back to manifolds for me
Old Dec 28, 2005 | 04:52 AM
crack's Avatar
crack
I have a 79 f-150 supercab 4x4 with the 400, and jsut bought flowtech headers for it, what kind of stuff gets in the way, and is it still pheasable to fit the headers in?
Old Dec 28, 2005 | 12:35 PM
beeboy's Avatar
beeboy
Many things can get in the way. The frame, starter, front driveshaft, dipstick, tranny. Depends on how the headers are built. I sent a pair of dynomax's back because they hit the frame and barely clearanced the driveshaft, ended up with Hedmans instead.
Old Dec 28, 2005 | 01:06 PM
gier-head's Avatar
gier-head
Here's what I have found for a 1978 F350 2WD 400M 4speed on floor:
Summit Racing: Dynomax WLK-85051 $109.95
Jeg's: Dynomax 289-85051 $109.99
Same header. Steel, painted, 18 gauge, 5/16" flange, 1-3/4" primaries, 3" collector.
Just a standard header. Nothing too fancy.
Was told about a Hooker 6914-1 that would fit also, but can't find anyone online stocking it.
Old Dec 28, 2005 | 08:26 PM
havi's Avatar
havi
I'll have the Roast Duck
I listed the hooker header from a P.A.W. catalog(2004). try HOO-6914 in their catalog. it says f100, f250, but I don't think there's any difference up front for the f350. however dynomax is certainly cheaper.
fordf2501
May 3, 2016 10:59 AM
Andrewfriend
Mar 22, 2016 10:13 PM
CaptainJack_7
Oct 18, 2015 05:42 PM
Ferrariferg
May 13, 2012 12:06 AM
1981 F250 460
Apr 12, 2005 03:48 PM
