Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Fog Lights OFF.....High Beams On
Old 12-19-2005, 07:59 PM
stevef100s's Avatar
stevef100s
stevef100s is offline
Has anybody come up with a solution? I just found this out over the weekend. For some reason, Ford designed things screwy. I for one, would like my fog lights to stay on while the high beam headlights are on. My friends Toyota is the exact same way.
Old 12-19-2005, 08:29 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
I installed a jumper wire on the switch of my 94 (in 96) and it works fine and no troubles.
Old 12-19-2005, 08:39 PM
Bdox's Avatar
Bdox
Bdox is offline
They are like that because of legislation that fog light should only operate with low beams.
It's easy to change. Splice in a new hot wire to the fogs that is independant of the light switch.
Old 12-19-2005, 09:29 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
no need for a new wire. do a search for this. you need to ground out a prong in the relay. also the law has nothing to do with Fog lights by themselves . it simply states it is illegal to exceed a certain amount of watts. this is a serious offense here in cal will run you 500.00 and a fix it ticket.
Old 12-19-2005, 10:18 PM
stevef100s's Avatar
stevef100s
I DID do a search first. Wouldn't you? I looked up fog lights under the Lightning section. I read for two days (not quite), but found nothing of what I needed. Any better help, then "do a search"?
Old 12-19-2005, 11:37 PM
ford390gashog
there is a write up at f150 online.
Old 12-20-2005, 01:00 AM
Bdox's Avatar
Bdox
Bdox is offline
Look up the law before you dismiss what someone else says. Who knows? They just might be in possession of a fact or two that you are unaware of.
Old 12-22-2005, 12:50 AM
Smaug's Avatar
Smaug
Smaug is offline
no need to mess w/ the wires, you can drill out part of the switch.
EDIT:just spent 30 minutes looking for a link and can't find it. I'll look again later and post it. It's either in the 97-03 F150 or Expy forum.
Old 12-22-2005, 09:49 AM
Smaug's Avatar
Smaug
Smaug is offline
found it and you do have to put a jumper in
https://www.ford-trucks.com/forums/s...d.php?t=234912
robinsonpowerstroke
6.7L Power Stroke Diesel
39
11-13-2019 06:58 AM
grizz 454
1999 to 2016 Super Duty
08-17-2015 09:02 PM
400Nut
05-20-2012 02:25 PM
ZeroTucker
17
05-07-2012 02:03 PM
stumpulla
2004 - 2008 F150
05-23-2011 09:24 AM
Quick Reply: Fog Lights OFF.....High Beams On
