Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Best Tool for Rounded Off Nuts
Old Dec 17, 2005 | 02:00 PM
dcdave's Avatar
dcdave
Best Tool for Rounded Off Huts
What's the best tool out these days for removing a 1/2" starter bolt with a rounded off head?
The exhaust accumulation pipe and the two tranny to radiator cooling lines are in the way too. :-)
grrrrrrrrrrrrrrrrrrrrr
Old Dec 17, 2005 | 02:06 PM
ford390gashog's Avatar
ford390gashog
craftsman has a new bolt out tool for rounded heads. the set is 30.00 and works pretty well. i used it to remove some egg shapped bolt heads and it worked great, took them out in no time flat.
Old Dec 17, 2005 | 02:10 PM
rswhitmore's Avatar
rswhitmore
Metwrench set also works pretty good on rounded-off nuts and bolts.
Old Dec 20, 2005 | 09:49 PM
FSC's Avatar
FSC
I have the bolt-out set from Craftsman and it works very well, you may be able to buy them individually but the set is not that much money.
Old Dec 21, 2005 | 12:46 AM
Chilako's Avatar
Chilako
Try driving a slightly smaller (12mm) socket on to the bolt head. Works for me most of
the time
Old Dec 21, 2005 | 09:05 AM
97F250XLT's Avatar
97F250XLT
I have a set of Snap on turbo sockets they work very good. I think they are the same as Sears but came out several years before Sears. You don't nedd them often but when you do they have worked well for me.
Old Dec 21, 2005 | 10:03 AM
jake00's Avatar
jake00
I use the hammer and smaller socket method
Old Dec 21, 2005 | 01:20 PM
sublimecharger68's Avatar
sublimecharger68
curved Jaw Vise Grips can also due wonder's when your in a bind.
just an Idea
sublime out
Old Dec 21, 2005 | 04:45 PM
Fair 96's Avatar
Fair 96
Vise grips if you got the room..
Old Dec 21, 2005 | 08:52 PM
rebocardo's Avatar
rebocardo
Depends on how many starter bolts there are and and if they are easily to access. Starter core is $12. If the bolts were rounded off and pretty much impossible to remove, I would just use a cut off tool, cut through the starter housing and cut the bolts clean through. Then once the statrer was removed use vise grips, PB Blaster, and some heat to remove the stubs.
If the starter would come off if only the heads on the bolts were removed, I would grind (chop with dremel) the heads off, pull the starter, weld a nut to the bolt end, and try twisting it off with a breaker bar. Though vise grips would get a chance before the welder since the idea with the grinder is to save time and I hate welding on my back.
Old Dec 21, 2005 | 09:06 PM
baitmaster's Avatar
baitmaster
A few yrs back, a bolt head on my bro's Chev van broke off. So we finally got everything off, and couldnt' find a replacement bolt at the store. so I bought same size bolt, but with a bolt head that takes an allen wrench. sure was easier to get in there than a wrench. dont forget the anti-sieze.
Old Dec 26, 2005 | 02:22 PM
tude's Avatar
tude
torch and vise grips works great for me
Old Dec 26, 2005 | 02:49 PM
oldgoat49's Avatar
oldgoat49
I have used a small pipe wrench to get rounded out drain plugs out. If you have the room they work pretty decent.
56efffie
Oct 12, 2012 09:07 PM
dcf4x4
Apr 29, 2010 11:15 AM
2 stroke man
26
Jun 6, 2008 05:57 AM
wavinwayne
Oil & Lubrication
Jul 16, 2006 09:13 PM
sethro
Offroad & 4x4
21
Jan 23, 2003 07:17 AM
