Transfer Case
Old Dec 14, 2005 | 06:10 PM
s8whiskey's Avatar
s8whiskey
Transfer Case
I have a 93 F150 4WD 5.8L W E4OD and I dont know what transfer case I have and I wanna know if I can twin stick it? Anyone know what the code or what it should be just fromt he year and such.
Old Dec 14, 2005 | 07:01 PM
thesprocket26's Avatar
thesprocket26
I will guess you cannot. Look on the transfer case and see where it connects to your in-cab shift arm. If there are two rails that move in and out of your tcase you might be able to twin stick it. I'm also going to guess you have a chain drive tcase and I haven't heard of twin sticking a chain drive.
Old Dec 14, 2005 | 07:25 PM
s8whiskey's Avatar
s8whiskey
There is only one. Damn it. So how much am I going to spend on getting a transfer case I want? or can I get one from a salvage?
Old Dec 14, 2005 | 07:41 PM
ivanribic's Avatar
ivanribic
You want an NP205. Prices all depend on where you find them and what condition they're in but $50-$300 is what they generally go for. Then you need to make some simple internal modifications and either build the shifters or buy them and viola, you're set. Look in the offroad forum for more info: https://www.ford-trucks.com/forums/s....php?p=3212557
Old Dec 14, 2005 | 07:52 PM
s8whiskey's Avatar
s8whiskey
Wicked. Ok one last question. What trucks did they come on so I know what year to pull it off of? And thanks for the comments thus far.
Old Dec 14, 2005 | 08:41 PM
ivanribic's Avatar
ivanribic
I don't know if they're used on any of the 80's trucks but the 70's 4x4's used them. Make sure you get a 205 and not a 203. You can also find them on ebay, it can just be a challenge finding one close to you. They weigh 150 pounds or so and will be expensive to ship if you have to. Just be sure you get a Ford unit. Chevy and Dodge used them too but they'll be for a passenger side front axle so they won't work.
Old Dec 15, 2005 | 11:46 AM
s8whiskey's Avatar
s8whiskey
Will it bolt up to a E4OD or am I going to need a new drive shaft and adapter plates and such
Old Dec 15, 2005 | 01:53 PM
leadmic's Avatar
leadmic
It will bolt up if you cut a notch in the adapter for the shift rails. You wont be ablr to run a front drive shaft with an e4od. The trans is to wide and the T-case dosent have enough offset for the front drive shaft. The front driveshaft will hit the corner of the trans. You could change to a stick but then your computer will freek out because it dosent see a trans. You could get a computer from a stick truck but are you sure you want to go to all this trouble just to get a twin stick?
Leadmic
Old Dec 15, 2005 | 02:02 PM
s8whiskey's Avatar
s8whiskey
I had a feeling that it was to easy in my mind. Thanks for the input.
Old Dec 16, 2005 | 07:07 AM
The SnoMan's Avatar
The SnoMan
Yep, it has to be a NP203 and youi have to carefully modify shifter rails too as well as add a custom shifter.
Old Dec 16, 2005 | 12:14 PM
ivanribic's Avatar
ivanribic
NO, is has to be a 205. You cannot twinstick a 203 . . . it is a chain driven case. Modifications to a 205 are only made to 1 shift rail.
