computer problem or not
I have a 1991 ford F250 2wd with a 6 cly straight. I had a motor with 132000 miles. when i motor went out due to pre ignition which ruined two cylinders and cracked the head. I put new motor in and the truck and it repeated this problem again . know after changing allmost all timing related parts and a third motor it's starting over again. can my problem be with my computor or what.
Thanks gary
Thanks gary
Do you mean the charcoal canister or the coffee can looking vacuum reservoir on the fender? If it's the coffee can one then you do need it, it's part of the heating and cooling system. It keeps constant vacuum going to the servos that control the blend doors in the cab. In a '91 it's fuel injected, make sure that all unused vacuum ports are capped off, and make sure that your fuel pressure is correct.
