4wd does not work
Old Dec 11, 2005 | 09:59 AM
f150owner's Avatar
f150owner
4wd does not work
I bought a 1992 f150 this fall when I tried out the 4wd it seemed to work alright exept the shifter need to be worked loose do to lack of use and the front end was a bit noisy at first.Then I didn't try it again untill the snow came and now the front wheels are not engaging.I crawled under the truck today,while the vehicle was off and in park with manual hubs unlocked ,I spun the front driveshaft and nothing else moved.Would this mean my pinion or gear is broke or worn out?Could anyone help me troubleshoot wether the problem is in the axle,trasfer case or shifter. thanks for any help James
Old Dec 11, 2005 | 11:11 AM
Oval_obsessed's Avatar
Oval_obsessed
Where did you have the transfer case shifter? 2h or 4h? If it was in 2h, the front drive shaft is going to turn. Lock your hubs and try it again. The driveshaft should not turn now since the hubs should be connected in.
Old Dec 11, 2005 | 11:18 AM
f150owner's Avatar
f150owner
still spins
Its in 2wh .I tried again with the hubs locked and the driveshaft still spins freely
Old Dec 11, 2005 | 11:58 AM
Oval_obsessed
If the hubs are locked in and it still spins, you have troubles. It could be a number of things, hubs, broken axle, ring and pinion thrashed. To see if the hubs are the problem, leave the hubs locked in and spin the drive shaft and see it the knuckles are turning. It sounds like you have a pretty big problem.
Old Dec 11, 2005 | 12:20 PM
f150owner's Avatar
f150owner
The hubs lock onto the axles fine so i geuss my diferential is shot. I'm going to make a new post and see if any one can help me identifie my gear ratio the rear end tag# is s8368 3 08 88 ze1s thanks for your responce James
Old Dec 11, 2005 | 11:21 PM
Peter94's Avatar
Peter94
It appears you have 3.08 ratio and an 8.8" rear axle. You probably have a dana 44 reverse cut differntial up front. If your spinning the driveshaft up front, and NEITHER of the axles (left or the right) are spinning, then yeah, you got diff problems. It would be considered normal if you spun the driveshaft and only 1 axle spun (that is if you have the hubs unlocked).
Old Dec 12, 2005 | 04:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
