351M that's bored .060 over
I bought a used 351M that has already been bored .060 over. According the date on one of the bearings from the main journal it was rebuild in 1997. I have done some searching and have learned it is a bad idea to bore .060. My question is " since this engine has been already running for several years do you think it would be safe to refresh it and put it back on the road?". It has been unused since 2001. I pulled the heads and the cylinder walls look good. I was thinking of slipping in new rod and main bearings while it's on the stand. I have heard that on a small block chev that it's a bad idea to put in new rod bearings unless they are resized because the big ends sometimes get out of round. Is this a problem with 351M rods? thanks Jeff
This block was bought to replace my original engine which I know is all stock( not bored ). Since my replacement block is bored .060 over ( which I did not know of this when I bought it) I think I am just going to bearing, ring it, and install a new cam. Since it's .060 over I fear if I stroke it to a 400 I may have some overheating issues. Later on I may turn my original block into a 400. Thanks for all your input and have a Merry Christmas. Jeff
Zack88
13
01-22-2016 05:28 PM
302 F-150
18
09-03-2008 01:11 PM
Superdave
16
02-13-2008 11:08 AM
Lifted78
13
07-16-2005 01:33 PM
