i keep fouling plugs
Old Dec 10, 2005 | 01:24 PM
busted knuckle's Avatar
busted knuckle
i keep fouling them its a carbon foul stock carb and all just the headers added
its an autolite plug usually have no problems at all with these plugs any advice on something i missed or a different plug? thanks again fellas
Old Dec 10, 2005 | 01:30 PM
ford390gashog's Avatar
ford390gashog
do they have oil on them???????? what size main jets? what is your vacuum reading? gap? mixture?
Old Dec 10, 2005 | 02:01 PM
53fatfndr's Avatar
53fatfndr
What Autolites are you running? 25's? You could go to a 26, a hotter plug, and that might take care of it. However, start with a stock plug and see if you can cure it by checking one of the suggestions made by ford390gashog. Going to a hotter plug might just mask a problem if this just started.
Here is a link to Autolites's website and their spark plug section. There is a lot of good info on reading plugs and choosing plugs and such...
EDIT: On rereading your post, it is quite possible that since you added headers that you need to readjust your carb settings. I had to on my stock '79 F350 400 engine, and all I did was swap out the muffler to a Flowmaster.
http://www.autolite.com/carcare/techSpecs.php
Old Dec 10, 2005 | 07:34 PM
busted knuckle
no oil on plugs they are gapped at 44 mixture is still a tad rich for my likings cant remember vac andd jet size at the moment it was 2:30 in the am i was thinking i might need a hotter plug. thanks for the replies
Old Dec 11, 2005 | 09:07 PM
derherr65's Avatar
derherr65
Punctuation and grammar not only show your command of the English language, but also make it easier for people to answer you.
bert cook
Apr 11, 2015 07:04 AM
quakerj
Oct 16, 2014 12:17 PM
Silvabullet78
24
Apr 3, 2012 10:34 AM
mikejaros
Oct 6, 2011 01:30 AM
norvillebob
31
Nov 9, 2006 04:58 PM
