57 F-100 9 inch Rear End vs 57 car rear end
I have read that the preferred (from a great tech article I read on this site) rear end for my 1950 F1 is a 57-72 F-100 9" inch.
I have a question. Is the 1957-72 Ford F-100 rear end the same as the 1957 car rear end? I have an extra 1957 (or 58) Ford car rear end and would like to know if it is the same or usable.
Next question would be if the 3.10 3rd member from the 57-58 Ford car can be used in place of the the 57-72 third member.
Thanks for your collective advice.
Dick
Dick
Dick
Dick
Looks like you already have done a bunch on your truck - that engine looks good and I see you adapted it to a different transmission.
As to your rear end, you sure you do not already have a 9" installed? I can't really tell from the picture but it could be. If the only opening in the housing is in the front it most likely is a 9".
You can read all about the 9" and see lots of different pictures here: http://www.kevinstang.com/Ninecase.htm
This is the site I use when there is a 9" question, and I have never found any mistakes.
If you wish you can post a picture of the front and back of your rear end, plus any case numbers you see and we can help identify it.
Welcome aboard, and keep us posted on your progress. It is nice to see an old flat head being brought back from the dead.
hotrod48
1957 Rear End.
Thanks for all the great info.
I was not aware that Gibbons stopped making front ends. I must've bought one of their last ones in January 04. The 50 Ford F1 project is going slow but still moving along. This winter I hope to finish the hooking up and restoration of the Charger tortion bar sytem that I bought. As to be expected, I was sold the wrong item (the disk brakes, calipers, spindles and lower support arm) that came form a later Chrysler product front end. By the time I finally got replacements - it was spring and I was driving my 50 Ford Convertible.
Yesterday, I pulled the rear end, leaf springs and shocks from my 50 Ford Convertible in anticipation of receiving the Jamco suspension items. I'm putting in the 58 Ford rear in that car.
With any luck, I'll be done in abut a month and then it's back to work on my 50 F1. I'll finish the front end and chassis this winter.
Dick in Massachusetts
Ax,
When you say Gibbons went out of business totally in .....
Do you mean the fiberglass business?
The guy with the IFs adapter kit wasn't really a part of Gibbons per se, he was just somehow associated with them. Perhaps using his business license or something like that.... There is a chance that the IFS guy might still be around, although finding him might not be easy.
Too bad, it looked like a real sharp kit. (I checked it out very thoroughly and would have gone with it except for circumstances at the time).
Good old 'Rage loved his. (Never hear from 'Rage anymore.....)
