Superchips 1715 on V10 Q's
Got mine tonight and programmed it. How many programming options is it supposed to have? I thought it allowed for 87 and 91 octane programming. Yeah, I can make adjustments for the shift points and shift pressure, but that is it. I was pretty disappointed that it didn't give me the option to adjust for gearing and tire size to fix the speedo.
Is this all you get with the 1715? I expected more.
Anyway, does anyone have a 00-04 Excursion that they were able to program for tires and speedo?
Originally Posted by MotorHaven Guy
You should be able to adjust the octane on it. None of the tuners support speedo recal with the V10, because of the way the speedo is picked up by the computer. You'll need to have a dealer do it, or get a Superlift TruSpeed.
I programmed my truck with the 1715. Basically it "should" allow you to pick 1 of 3 programs. 87, Tow, or Performance. Tow and Performance requires 91 octane. On the 99-2004 V10 Fords, they cannot be corrected for tire size or gear ratio by the 1715 do to the type of speedo they have (dial type). Superchips told me only the digital speedos can be corrected (guess the 5.4 trucks have that). Anyhow, I was able to select the "tow" program, change my trans. shift points for every gear change, raise the rev. limiter, and changed the shift firmness. The on screen instructions are pretty easy to follow. If you do not have the option to change to more than one program, something is wrong with your programmer I think.
