Aerostar Ford Aerostar
92 universals
Old Dec 8, 2005 | 10:05 PM
roree's Avatar
roree
92 universals
Judging from the clunk when I go out of park and from first to second, I think it is time for universal replacement. I have done this job before but not on the Aero. Anybody got any tips or pointers? Thanks.
Tony
Old Dec 9, 2005 | 10:40 AM
bertha66's Avatar
bertha66
Jack her up, put it on stands and pull the shaft. Use a press if you can, it is easier than a hammer and better on the shaft and joints.
Old Dec 9, 2005 | 10:57 AM
copper_90680's Avatar
copper_90680
Put a pan under the rear of the tranny when you pull the shaft. There will be some ATF coming out the rear as soon as you pull the shaft.
If you don't have a press, use a big C-clamp to press out the U-joints.
Old Dec 9, 2005 | 11:48 AM
VanGo's Avatar
VanGo
If you can handle the downtime, it would be a good opportunity to get the driveshaft balance checked. The shop can install the U-joints too if you want.
Aero driveshafts are aluminum so you need a drive shop that works with them 'cause the only way to add weights is to weld or glue them on. Welding aluminum is a specialty.
A unbalanced driveshaft can cause vibrations while driving.
Old Dec 9, 2005 | 12:58 PM
96_4wdr's Avatar
96_4wdr
center punch mark the driveline to pinion end alignment...can get 180d off from original
i would have a shop with dynamic balancing dl equipment put the new u joints in....so critical for long life of u joint, auto tranny rear and pinion bearings...if not...be sure to seat cups against ring locks by rubber mallet wack on cup mount rings
