10k mod no worky for me..Dissapopinted
Keept giving me a check engine light,,reset the computer 3 times and 3 times it came back. So I started upping the resistance until I got rid of the code,,had to run 14k to not get a code. Ran VERY strong till about 2000rpm then fell on its face,,Took it back out ran fine again.. So in conclusion,, in my case it was a bust.. Dissapointed because right until it nosed over it was pulling like a bear.
Did the other resistor mod (oil temp) and that one went fine. Doesnt feel any different (my butt dyno is used to much bigger changes,my last daily driver was an 11second Lincoln ) but no codes..
__________________________
WWW.HOTRODLINCOLN.ORG
"Dog Hair Racing"
2004 GTO ,Almost stock,3790lbs , 1.7 60FT / 12.8@106
1996 F250 Powestroke,3" dp,no cat,5"tip,46637 filter,not quite as fast
1972 Oldsmobile 442 ,work in progress
"Dog Hair Racing"
Nope didnt get the leads in the wrong terminals and I didnt run the wires in the connector like that.. Too rigged for me.. I peeled the insulation of the two correct wires and soldered the resistor.
Again,if you read my original post youll see I had a check engine with the 10k,once I upped the resistance to 14k it ran fine and very strongly until above 2000rpm where it nosed over. My thoughts are its either running out of fuel or the computer is defueling because of too high boost.
"Dog Hair Racing"
"Dog Hair Racing"
High pressure oil could be the problem, either in the ICP, the IPR, or the pump itself. The pump would have to be borderline for a 10K to overtax it.
Best bet would be to pull the code that turned on the CEL, that should give an starting point.
Im not gonna worry too much about it,,truck runs great as is without the resistor ,was just looking for a little extra pop but not to the point of risking problems...
___________________________
"Dog Hair Racing"
"Dog Hair Racing"
my truck ran like poo over 2k with the 10k, seemed like i was running out of high pressure oil.. a good chip will get you the extra power and not have to worry about problems like with the 10k. with my truck setup seems like the only codes i get are overboost, low hpop, and overspeed......
MacSuperDuty
10-02-2007 08:58 AM
Hypoid
21
12-09-2006 07:42 PM
ranger250Center
03-18-2006 10:00 PM
