Highway gear for a 223?
I am having my third member rebuilt locally. While I am at it I am considering going to a ratio that would get better MPG than my current 3.89. What would be the lowest ratio I could go to & not overload my 223ci. 6cyl.?
'63 F-100 223ci. 3spd. lt. duty manual
Thanks for all advice.
John
John- thanks for response. I have seen others say the same thing about going with a used unit. Here in central texas I have not found one for under $200. And, that is with no guarantee that its in any better shape than mine, & finding one in the ratio I am looking for seems impossible.
I was thinking about the 3.50 also. Maybe I'll go with that. I'm still waiting for my shop to tell me EXACTLY what needs to be replaced. Anybody else had any experience with switching gears on a 223?
Thanks
Thanks
tgunn, Do you have your email feature turned on? I'll bet one of your Texas neighbors can shoot you a mail with a lead on one. You are correct, about getting a guarentee with one, most yards in North Carolina will replace a part if it is not right. You should be able to purchase an open 3.5 28 spline chunk for $50-75.00
Your truck engine can't handle anything below that with out lugging it. They have to make rpms to make power.
John
John
Thanks
Thanks
I only did it because I intend on going to a big block v8 by the end of 06 (and swapped the 9" out for a dana 60 already geared 3.50) but in the interim, it really lacks go.
Originally Posted by ford390gashog
the gear ratio won't thrwo off the speedo as long as you run stock size tires which determine your final gear ratio.
Having changed gear ratios on my truck or jeep at least six times in the last year.. that's the most incorrect statement I have heard in a long time.
I'd reconsider the swap to 3.50's. They'll probably work, but I doubt you'll see a big gain. You'll end up working the engine harder to get it moving which will use more gas... If you're buying new gears I'd go no less then 3.70... If you get a $50 or $75 chunk that's a 3.50, then I'd try it, but I wouldn't spend the $350+ on rebuilding you're rear and take a chance that you went too high...
I'll bet you'd get more gas mileage from covering up the bed then going to a 3.50 or higher ratio... Just my thought...
David
David
Well, right or wrong, I did it. My Ford 9" was shot. So, I had it rebuilt with a 3.50 gear. So far I like it. The engine no longer sounds like its screaming at 55-60 mph. I will admit that I sometimes have to get a running start at some hills in my area. I have not checked my MPG yet.
I don't use my F100 to tow anything. I just drive it to work 25miles each way, & use it to haul stuff I don't want to put in my Tahoe.
What is it about these old trucks that makes me feel I've made a good investment when I have spent about $3k on a $1500 truck?
Because you are fairly sure you'll still be driving that $4500 truck in 10 years. I bought mine for $2250 (4x4, costs more) in 1991.. I'm still driving it. It served as my daily driver a little more than half that time.
joeplouff
02-09-2016 09:19 PM
8lugthug
05-05-2014 06:20 PM
riskman
17
04-10-2013 10:01 AM
knuckledragger66
03-31-2012 08:17 AM
60FordF100
08-29-2007 04:43 PM
