e40d
Old Dec 1, 2005 | 12:15 AM
mhannink's Avatar
mhannink
e40d
ok well ive got 2 questions one is my tranny is gear hunting around 35 to 45 under light throttle and i can't figure why the second is does anyone know how to wire a mystery switch to control tc lockup on these things the truck is a 90 250 7.3 idi no turbo e40d trans idk rear gears if someone has an idea that would be kool anyways any help will be appreciated thanks
Old Dec 1, 2005 | 05:34 AM
trike1946's Avatar
trike1946
Do you have any codes? How many miles on the trans? Is the fluid clean and full? Is the OD light blinking? Does it still hunt for gears if the OD is turned off? I don't know of a mystery switch. If the trans is good and the sensors are good and set to spec. you should not need any thing else.
Old Dec 1, 2005 | 08:02 PM
mhannink's Avatar
mhannink
i havent tryed to pull codes mostly idk how and idk if kragen knows how no the light is not blinking trans fluid is hurts hot sift it full and brand new alnog w/new filter so its clean 155000 miles on it i asume its all origanial but i don't really know havent tried to turn off the od should try it
as for the mystery switch this truck is turned up and the extra clamping force when in the other gears will help racing from light to light and when i wanna screw around. its mostly for control of the trans(and another switch) i like manuels and so this makes it feel like it more tho not near the same
ford390gashog
Ford Truck Parts for Sale
Sep 12, 2012 03:19 PM
justinmayeux
Louisiana Chapter
Jul 30, 2012 10:33 PM
arkredneck
28
Aug 10, 2011 06:24 AM
regidog
Sep 7, 2010 02:05 PM
4wheelinbroncos
Aug 22, 2004 06:12 PM
