Started once now it wont start
Old Nov 30, 2005 | 10:19 PM
OrdoDraconis's Avatar
OrdoDraconis
so had to go through and replace the timing cover gasket. pulled the radiator and had it clean while it was out. had the battery un hooked as well. put everything back in and had to replace the throttle cable.
well when i gave it the test start after that started up fine idled high but it was also 46 degrees outside. then i killed it to check every thing was secure no oil leaks the normal. wouldnt start after that.
just to update you on the history rplace the whole fuel line, from intank pumps to inline pump. as well as the following parts:
cap and rotor
fuel filter
plug wires
ignition PIP
ignition module
alternator
starter
a whole mess of fuses
(i also double checked them.)
2 intank fuel pumps and the high pressure pump under the body
spark plugs
coil
i replaced these cause they were MIA when i got the truck, it been under 7 months
i do get spark
i had a nasty oil leak and it got everything covered in oil so i was planning on taking it to the superwash and spraying the inside with some degreaser
im out of ideas offer some advice if you can
it alos ran before i did the Timing Cover Gasket
Thanks
Old Dec 1, 2005 | 01:20 AM
shade1965's Avatar
shade1965
is it sparking? if not that magnetice pickup under the distributor cap will die real quick like and it will cunfuse the heck outa ya i know,lol well hope it works out, charlie
Old Dec 1, 2005 | 11:09 AM
OrdoDraconis
Well checked the fuel pressure i could only do the key on test no pressure um this just like what happen when i had to replace the fuel pumps dont worry about the Fuel Cutoff Switch i have it bybassed its broken i need to replace it but for now its bybassed????
Old Dec 1, 2005 | 01:12 PM
OrdoDraconis
replaced fuel pump relay, just an idea i unhooked my battery just to see what happens. it sparked alot when i put it back in my wrench touched im wondering if i overloaded something i had a blown fuse so i repalce that as well.
Old Dec 1, 2005 | 01:46 PM
OrdoDraconis
okay so i unhooked the battery for about 30 mins and hooked it back up and it turned once and started the next time around i shut it down and tried again strarted right up kinda wierd maybe i just overloaded something im not sure, im gonna leave this thread open maybe you guys can up with a secanrio for the problem or something no idea.
Old Dec 1, 2005 | 01:54 PM
OrdoDraconis
oh by the way this truck is a 87 F-150 EFI 2wd
Jymmm
21
Apr 3, 2019 12:52 AM
Beauderek
Sep 17, 2011 04:51 AM
3BadBirds
Jun 21, 2009 04:39 PM
dakota-boy
Jan 24, 2009 02:37 PM
72F250390
16
Jul 15, 2005 05:20 AM
