cruise control fix
Old Nov 30, 2005 | 06:29 PM
otpracer100's Avatar
otpracer100
cruise control fix
Hey anyone out there who had a cruise control issue with the wires getting damaged in the steering column?Iwas just curious as to where the wires went bad?The only place I can see where they may get damaged is behind the wheel where I can't get to with out yanking the wheel.
Old Nov 30, 2005 | 07:49 PM
1997F-350's Avatar
1997F-350
whats the problem?
1.cutting of cruise when you apply turn signal??? burnt out bulb in rear/ 3rd brake light.
2. the contacts get dirty behind the horn pad and you gotta pull it to clean it.
please specify whats up.
Old Nov 30, 2005 | 08:11 PM
otpracer100
I've got absolutely no cruise functions at all.There are no blown fuses and all the lights work.I remember reading a post about the wires in the column chaffing or something.
Old Dec 1, 2005 | 04:39 AM
1997F-350's Avatar
1997F-350
if you got tilt i would check that area first.
Old Dec 1, 2005 | 06:34 PM
believer45's Avatar
believer45
There is a pressure switch on the master cylinder that often fails. Try unplugging it and jumping across the two terminals in the wiring harness that plugs into the switch. If the cruise then works there is your problem.
Mine did the same thing and it turned out to be the wires on the back of the horn pad not making good contact. I removed the horn pad, moved all the wire connections around and reinstalled the pad - been working fine since.
Dave / Believer45
Charlie704
Mar 25, 2017 04:52 PM
eagleye
WTB - Parts & other
Feb 27, 2017 06:35 PM
biggdirty7.3
Feb 2, 2017 10:13 PM
bobbyt89
31
Jan 27, 2013 07:38 PM
German Joe
Sep 26, 2012 03:17 AM
