Drag Link Bracket weld failure
Old Nov 28, 2005 | 01:29 PM
quietman's Avatar
quietman
Yesterday i noticed the steering suddenly becoming vague and that the wheel was no longer centered when driving straight ahead.
Examined the front suspension and discovered that the welds holding the drag link to the frame had failed. A closer loook revealed that most of the bead surface was already rusted, and obviously had failed long before and/or never had any penetration.
Now I need to see what i can have done about it.
I have friends/relatives who are master welders and work building race cars/off-road trucks and doing Aero-space welds on rocket nozzles etc.
Obviously my first choice.
If for some reason I am forced to go through Ford or some commercial frame/suspension shop i would be interested in reccomends for the Greater Orange County area in Southern California.
I would appreciate any advice, and will update as warranted...
LINK to photos etc. :
http://www.martialartsacademy.org/leviweldfailure.htm
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein mono-gas shocks, Rancho Steering Stabilizer
Silverstars, BFG 295/75/16 AT KO's on Factory Mags
LANDYOT Generation II Radius Rods, Ford factory hood insulator
Old Nov 28, 2005 | 02:53 PM
l-m tech's Avatar
l-m tech
the ones i have seen broke i rewelded and added a gusset to stiffen it up and they havent come back yet.
Old Nov 28, 2005 | 03:20 PM
cficare's Avatar
cficare
Isn't that the steering damper that's bolted to the cracked bracket?
Old Nov 28, 2005 | 04:29 PM
quietman's Avatar
quietman
It is a bit unclear from the picture, but both the drag link and the steering stab are attached to the same bracket. The link is above and parallel to the SS.
Quietman
www.roenation.com
Old Dec 1, 2005 | 05:06 PM
kdsmgb1's Avatar
kdsmgb1
I have to wonder if that 4" lift is going to get you in trouble with Ford on any warranty claim. I would go with your welding buddies and whatever they suggest, plus gusseting as suggested here. Build it up to deal with that lift and the leverage the lift puts on the suspension, especially side-to-side action. I wheel the h*ll out of my '71 Bronco with 35" tires and the new track bar welds we just put in (71k lbs/sq in.) are stellar. Your buds will do a better job than Ford. Doesn't sound like it's far enough gone that you're going to need some ort of jig or alignment expertise from Ford. -Ken S.
quietman
Aug 30, 2025 03:41 PM
quietman
Apr 23, 2017 11:15 PM
quietman
Oct 18, 2014 07:56 AM
krewat
6.2L V8
27
Apr 23, 2008 04:21 AM
quietman
Oct 24, 2006 02:48 PM
