Water purge button or valve?
on
Welcome FTE!
There is a valve with a yellow lever on the back side of the fuel filter housing. Turning this lever clockwise will drain the fuel from the housing thru a long tube that exits from under the front of the engine on the passenger side. I usually place a hose on the tube to catch the fuel in a bottle to check for water.
