Major progress!!!
Old Nov 26, 2005 | 10:44 PM
Putt's Avatar
Putt
Major progress!!!
I am finally getting things together on my '66. I completed the front disc brakes, the rest of the new brake lines and hoses, tightened up all sorts of loose bolts, wires and assorted stuff today. I need to finish the fuel cell install and the new fuel lines and its ready to LIGHT"ER UP!!!
I'll get some pictures to post tomorrow, I was too busy putting things together to take pictures today!!
I am leaving the front fenders off until I get it into my shop, the weather is getting a little harsh for working on it outside
Hope all had a Happy Thanksgiving and enjoy the rest of the weekend!!
Old Nov 27, 2005 | 07:38 AM
jowilker's Avatar
jowilker
Congrats on the progress. I know you have to be excited.
John
Old Nov 27, 2005 | 10:00 AM
Putt's Avatar
Putt
Thanks, John. Yeah, I am pumped, it has been over 4 years since it was running. I was going to repair the cab mounts/core support only, but then thought " Hey I can upgrade the front brakes and replace the fuel tank while I'm at it." So it turned into a bigger project!
Old Nov 27, 2005 | 01:35 PM
jav409's Avatar
jav409
Did you add power Assist to your Disk Brakes ? I did , and the differance in stoping power is amazing from the drums. no point in jacking up the Horse power if you have to book ahead to make a stop. :P
Old Nov 27, 2005 | 07:24 PM
Putt's Avatar
Putt
jav409-I did not make them power disc at this time. I am desperately trying to get it moveable under its own power so I can run it in and out of my shop(1 car shop) while still working on other projects.
Old Nov 27, 2005 | 11:17 PM
Putt's Avatar
Putt
Soooo Close!!!
Here are pictures of my NEW disc brakes, the first also shows the left cab mount and parts I replaced.
This shows some of the right side suspension, steering linkage(all new) and the right front cab mount that I welded in with the new polyurethane cab mount bushing.
This is a shot of part of the core support, it takes a look at the condition of it before this photo to really appreciate(a picture is in my gallery under progress).From junk to OK I hope.
The frame horns for the cab mounts also needed repair, which is why they are bolted on now. The white stuff around the edges is SNOW, I need to get it operational so I can get it inside to work on it!!!!
Old Nov 27, 2005 | 11:48 PM
minishtr's Avatar
minishtr
Putt,where did you get the poly bushings from?It's nice when you can see some real progress.
Old Nov 28, 2005 | 12:10 AM
Putt's Avatar
Putt
They are Prothane bushings I got from JC Whitney some time ago. The harder part of the mounts are the OE Ford sleeves and nut/washer seen in the picture.
It is nice to see it coming together, for a while I didn't think it would ever be a truck again!!
Old Nov 28, 2005 | 12:43 AM
Bdox's Avatar
Bdox
Nice job, good idea.
Old Nov 28, 2005 | 01:44 AM
ZombieSlayer's Avatar
ZombieSlayer
I know that feeling
Congradulations on the progress I have a question (more out of curiousity than anything else), why that location for the msd box?
Old Nov 28, 2005 | 09:18 AM
Putt's Avatar
Putt
The MSD is supposed to be mounted in a cool location, I had some trouble with it on the drivers inner fender. It now gets cool air from the grille whenever moving and is away from the engine heat all the time.
Old Nov 29, 2005 | 05:30 AM
jowilker's Avatar
jowilker
Putting it out where it can be seen like that is asking for it to be stolen. IMHO
John
Old Nov 29, 2005 | 09:21 PM
Putt's Avatar
Putt
The grille covers it up when I finish, so it will not come out easily at all.
If you mean while I am working on it...I live in a rural area with a long driveway and a BIG dog that makes lots of noise. Most people around here understand who calls 911 when a robbery is in progress
It's the crook calling for an ambulance to stop the blood flow!!
Old Nov 29, 2005 | 09:33 PM
ZombieSlayer
I was thinking about the vandalism aspect as well. But where you're at it's probably not that big of a deal.
Old Nov 29, 2005 | 09:37 PM
Putt's Avatar
Putt
You are correct
