Diesel Fuel in Coolant
I have searched the internet and found some information relating to having Diesel Fuel getting into the coolant and this seems to be the injector sleeves. Does anyone know how to narrow down what side, and/or what sleeve is causing the problem? What is the fix and about what do you think the dealer will charge to fix? Any recommendations for a dealer to repair in Michigan? The vehicle is a 2000 Excursion.
As far as I know, the only way to identify which injector cup is leaking is to remove the injectors and look. Best bet would be to have them all replaced. Dunno what theat would cost, I'd guess around $400 since the tech will pull the heads to remove the cups.
