Brake bleeding tool for a 78 f-150
This whole brake problem came about when I decided I needed to put on new brake hoses on my 78 f-150 4x4. I already put on the nice stainless braided brake hoses. Now I need to bleed my brakes. I am lucky enough to have set of 1978 ford truck shop manuals. It states in the manual, that I need to pull the bleeder rod outward on the Pressure Differential, Metering, and Proportioning Valve. It also states that I need to use Metering Valve Bleeder (tool J 22742). Where the heck do I get that tool or something that will work? What should I do?
If you guys have the shop manuals the page I am on is Chassis-12-01-19
I've bled many many sets of brakes over the years and have only ever had to mess with the plunger on the prop valve on one rig, and it was a Chevy that had completely lost the front brakes and the prop valve was stuck.
I like the gravity bleed method. I works well on almost any brake system and you don't need a helper. It takes more time this way though.
If you are using a catch container at the bleeder screws, just make sure you hose isn't submerged in fluid in the container.
Should you open up a valve on the prop valve? an when should you stop bleeding. I tried doing the rear with out opening any valve, and it seemed to work, but when I thought it was finished bleeding, bubbles would come out again.
This is my first time bleeding brakes, and would really appreciate a little more details.
Thanks in advance.
Thanks in advance.
Lightning23
89
09-06-2017 11:18 AM
ctubutis
07-27-2017 06:02 PM
BLK79
12-19-2016 02:14 PM
Rory
06-18-2004 01:36 PM
