4x4 not working, no power to switch and new motor issues
so this is my little sister in laws truck it’s a 98 4.0 automatic and when u key on the 4x4 high and low light flashes but nothing when I turn the switch. Checked all fused and the switch is not getting power and dos have ground. So where do I look up stream? And the new motor I got dosnt have the big wire that goes inside the t case.
go here BBB Industries- Premium Alternators, Starters, Power Steering Products | BBB Industries- Premium Alternators, Starters, Power Steering Products and make a user name and password,,,,then go to wiring diagrams and put in your truck,,,,and go to electrical dist then sub system power dist,,,,as you will see this works for a lot of years makes and models of cars and trucks,,,,save to desktop or bookmark,,,,and share
there is a battery saver relay on some models that has a LG/O ( i assume light green and orange wire) to electric shift control,,,,not sure if that is wire your after and out of battery saver relay it goes to fuse panel ,,,TY wire ( i assume tan yellow),,,,, there is also a transmission control switch that has a P/O wire ( i assume pink orange) that goes to fuse panel,,,,see if it has either of those,,,,those should be hot with KOEO
