Got rid of tapping noise on 2.9 EFI!
Hey, guys! Remember me? I wrote about heavy ticking on my '88 Bronco II after warm up to operating temperature and sometimes after cold start. I measured the oil pressure - it was very low even on 20W50 oil. So I machined the cranckshaft, installed +.25 main bearings and +.50 rod bearings. I also fixed the oil pump by removing wear traces from the bottom cover and took off the pump case about .10 mm of metal to cure endplay of the rotor. Now the pressure is OK, no ticking.
Now for the most interesting part. I was pretty sure that the tapping noise was produced by hydraulic valve lifters due to low oil pressure. But now I'd rather think that it was rod bearing noise. I found out that my cranckshaft was already machined by previous owner. Rod journals were machined to .25 (main were not tooled), but some pervert-embiciles installed .00 (standard) bearings. This, along with a significant wear, produced an enormous clearance in rod bearings, that I could virtualy feel fith my hand with rod big end caps bolted on.
Anyway if you think that your lifters make a tapping "diesel" noise the first thing to do is to measure the oil pressure.
And one more thing - DO NOT rely on engine flush, oil conditioners and other miracles. And I would also not recommend cleaning the oil pick up with a barrel brush ))
Russian Comrade D
Russian Comrade D
81ChopTop
64
04-23-2016 06:51 PM
Argess
13
10-16-2010 12:03 PM
ColoradoFordBoys
08-22-2010 08:16 PM
