Sponsored by: Real Truck
Diff. fluid leaking... Help!
Old Nov 19, 2005 | 02:48 PM
Cuda444's Avatar
Cuda444
Red face axle leaking diff. fluid... Help!
I recently did ball joints up front and now there is diff fluid leaking out of the axle tube on the drivers side. Does this mean that the inner axle seal is busted? How do I fix it if it is in fact the inner axle seal? Is this an easy fix? Leaking fluid means no 4x4 and snow is just around the corner. Any help would be greatly appreciated. I'd like to tackle the project just after Thanksgiving. Thanks in advance
FTE is the best
Old Nov 19, 2005 | 03:44 PM
Bear Hunter's Avatar
Bear Hunter
Sounds like the seal. I have a buddy that just had this repair done to his rear axle..I think he paid $175 or something like that.
Old Nov 19, 2005 | 03:53 PM
Cuda444's Avatar
Cuda444
Inner seal (meaning the one on the pumpkin side of the axle tube? Do you have any more details on the process?
Thanks for the response.
Old Nov 19, 2005 | 06:54 PM
Cuda444's Avatar
Cuda444
Anyone? ... Please?
Old Nov 19, 2005 | 08:08 PM
FortyFords's Avatar
FortyFords
You have to pull the carrier to replace the inner seals,what happens is the when you replaced your ball joints somehow you damaged the seals with the splined end of the
axle when putting it back in to the tube.If you want to do this you had better get a manual. because the ring gear and carrier have to come out ,then the seals or installed from the inside.
Rich
Old Nov 19, 2005 | 08:41 PM
Cuda444's Avatar
Cuda444
Thanks for the post. Do I need any special tools? Also, do you happen to know the part number for that drivers side seal?
Thanks again
Old Nov 19, 2005 | 09:18 PM
FortyFords's Avatar
FortyFords
Well the shop manuals show a special tool to put them in with,but guys have made their own tools.you also have to pull the axles again to get the carrier out
No part #
Rich
Steven Stocki
Dec 15, 2016 01:24 PM
Sharkster54
Apr 17, 2016 08:58 PM
JNG6
Feb 9, 2016 10:54 PM
Morning View Diesel
6.4L Power Stroke Diesel
Mar 4, 2015 02:43 PM
hotroddually
May 12, 2007 07:03 PM
