4.6 L in Aerostar clip
A deer ran in front of me last week. I think the Bluesmobile ('96 Crown Vic Police Interceptor) is a total loss. Bluesmobile vs. Bambi Death Match
I may buy it back at salvage mainly for the drivetrain. It appears the damage is isolated to the sheetmetal. Will the 4.6 drop in the Aerostar crossmember? I think grafting the front end to my spare frame is above my skill level. I could bolt the Aerostar in. I'd have access to all the wiring, sensors and computers. Has anyone here installed the 4.6 EFI? I saw a couple at the SuperNats. I haven't been able to find any information on the suitablity of the rear axle/suspension as a donor. Any thoughts on that?
Kevin
1953 Ford F-100
Go Illini
Kevin
1953 Ford F-100
Go Illini
Kevin, if you decide to put the Aerostar under your frame, contact me. I have done a couple of these swaps and they are the easist I have ever done. I would more than happy to come help you.
I know of a couple of 61-66 F100 that have the complete Crown Vic frame under them. I even drove one. The Slick 60's frames are the same width as the 53-60's. The Crown Vic should have a wheelbase of about 115" so it would have to be shortened for a 53-56. I presonally didn't like the look of the CV rear suspension in the trucks. You have to cut a large portion of the bed floor out to use the complete CV frame. They sure do ride nice though.
Kevin....don't know what your working on (thought it was a stocker), but I have a friend that grafted a Crown Vic front frame, to his '58 truck frame. I haven't seen it yet, I only see him a couple of times a year, but he said it worked out great. Just a thought........
______________________-
XFM...
XFM...
I do have a stocker in the works as well as a driver. This would be in anticipation of a project far in the future. If the salvage price is acceptable, I could get a good donor with a known history.
Kevin
1953 Ford F-100
Go Illini
Kevin
1953 Ford F-100
Go Illini
Deerslayer.....beware...once you go to the "Dark Side" there's no going back.
Kevin-
I think you will have to resolve the problem on electrical for the anti-theft function in the wiring harness. They usually won't start without the key in the original column which has some sort of interface with the computer. I'm putting a 5.4 Lightning in my 56 BW and that is one of the issues I'm facing. I have found two sources to bild a custom harness so far; Street & Performance and The Detail Zone, both want over $1200. I'm still looking since it is a ways down the road before I need it. I don't know if they will modify an original harness for you or not or what the cost might be. You might look at the possibility of using the Vic column.
Originally Posted by LEckart
Kevin-
EFI to use on my Cleveland
There are companies including Ford that are offering aftermarket "mini computer" and wiring harness for a number of the EFI engines that provide the AFI functions without all the interlocks and sensors (including the OBD tattletales). Some of these modules are so small they mount right on the engine.
Update:
I bought the Bluesmobile back from the insurance company for a whopping $119. Those salvage yards must be making a mint! I haven't decided what to do with it yet. I'm leaning towards parting it out.
Kevin
1953 Ford F-100
Go Illini
Kevin
1953 Ford F-100
Go Illini
