E40D up in smoke
Today, I was pulling a moderate-sized trailer, and I looked up and saw smoke boiling up from behind. I looked under the truck, and fluid was pouring out of the front of the bellhousing. The smoke was just fluid on on tailpipes, but the fluid was foaming as it hit the ground. The tranny didn't feel like it had failed or anything, and I heard no noises.
I found some other threads that mention "boiling-over". Is this the same thing? Where is the fuild coming from? Is there some sort of valve in the front pump that allows the fluid to come out when it gets too hot?
Looking at the other threads, it seems like everything can possibly still be okay after a new filter and fluid. I sure hope so.
Another thing is that I had noticed about 15 minutes before that my engine temp guage was reading a goo bit lower than normal. I though that was strange.
Steve
'95 Clubwagon XLT
Now, the thing isn't shifting right. It will go up to 3rd gear, and will not go into overdrive. I can hit the overdrive on/off button, and it wil go into OD then. When I slow down to a stop, it may of may not downshift. It feels confused.
Could it be the MLP/TR sensor on the side where the linkage is?
Another thing that may or may not be related is when we were binding it down on the trailer to haul it, we broke of the wire connection that goes into the top of the rear end housing. Now, the speedometer doesn't work, and the "rear abs" light is on. Could that affect the shifting of the tranny? What is that connection called, and what all does it control?
Steve
'95 Clubwagon XLT
