Just how big IS a 534?
I know I'm not the first to ask, but I couldn't find it in the archives. I'm building a '75 F-350 and wondering if a 534 will fit in there and what trannies will bolt to it. It's a frame up re-build of the truck, so now's the time to consider such things. IF anyone has any dimensional drawings or spec. for these engines I'd really appreciate seeing them. Thanks, Ogre.
The SD series 534 is a big, humongus, heavy, gas-guzzling engine, from what I've heard. Upwards of 1,000lbs. You might be able to make one fit, but it'd be a PITA IMO. However, you would get superb low end torque for towing, or whatever other work you plan to do with the truck. Plus, the "wow" factor of having possibly the biggest gas engine ever put in an F350.
I'm sure someone will come along with more specs.
A 534??? Thats what we run in my dads crane truck that weighs 30,000 lbs. If thats what you want, then good luck and have fun, but that thing is going to DRINK gas. We figure we get about 4 miles a gallon, although that truck does have a lot of stand-still loading duties that consume gas which are included in that number.
I've got the 534 in my boat, ripped out the gov.,boxed the carb and turbo-charged it.
It's hooked up to 2-1 ratio capitol gear, I'm hoping for a increased heart when I punch it.
Still trying to figure out how to post a copy of the installation spec sheet,it will show up, I think
Originally Posted by Ogrebonz
Well, the 390 in my 2wd F-350 gets between 7 and 9 mpg, how much worse can it get? Ogre.
Now the 460 has all kinds of speed parts, including stroker kits that can get you over your 534 cubic inches. There is simply no comparison.
Plus, I won't even harp on the weight differences.
Scroll down to "vital statistics" for dimensions.
https://www.ford-trucks.com/forums/s...d.php?t=220095
