My motor is toast!!!
The 351W H.O. V8 in my 84 Bronco took a turn for the worse this Summer, developing a very loud knock. Turns out that 2 pistons have bent connecting rods, and were hitting against the crankshaft. Aside from some chunks of metal in the oil, all of the rod bearings were shot, worn down and scored. Plus the oil looked like chocolate milk, so some water or coolant is coming in from somewhere.
I'm looking for suggestions on a good brand of short block kit, and what hey might cost. This engine was a NAPA longblock kit put in the Bronco just before I bought her. Only got about 20K miles out of it, so I ain't going back to NAPA for another motor!!!
How much you willing to spend? I would never get an engine from a place like Napa. I like to build everything stronger than it was originally. I'd take your block to get rebuilt, by a good shop and buy a complete kit for it from edelbrock so you know that all the new parts will work together without conflicting.
PS where you from in Texas i'm from Kaufman
Since the current engine block probably is cracked and no good, I don't intend to spend any $ on it. IT's already bored .030" over, and the cylinder walls need honing at least if not boring out to .040". I belive the heads are O.K., but would still have them re-worked if I go with a shortblock kit. Depending on what it costs locally to do the heads, I may scrap them, too.
I live near Palacios in Souheast TX. THanks for the reply!!!
Screw the 392. Go 514. Don't be a girly man.
I wanna get that 392 for my truck if I can ever get my head back above water. Or I may just steal the 514 from my mustang. Muahahahah
They have a $1,200 long block for the 302. You may wanna see if they have a 351w like that. But if I was you I'd just save up and get the 392 if ya can. Be prepared to get different intake injectors and exhaust to feed that baby
i replaced my engine on a 92 Bronco 351 v8 with an engine from a 93 bronco 351 v8 with just 70,000 miles on it. The engine cost me 900 bucks but with labor cost and the changing of all the hoses, belts , oil pan, timing chain and i put a new radiator in it for good measure, i spent almost $2,700 bucks. If you can shop around before you get one. If you can afford a new one, go for it. But look around and i bet u can find a very good used one for cheaper. I have 9000 miles on my new used engine and not one problem.
davdogg39, that's a good suggestion, too. I'm checking out a couple of running motors to swap into the Bronco and be done, without having to go thru the trouble of building one up, ordering parts, etc. One is a 302 race motor worth about $2K, the other is a 351W in a 95 Ford Lightning truck. Either of those will take alot more work, but would haul. I can find a ton of longblocks locally for under $1K, but don't have any more faith in those than the NAPA version. Still checking on a JAsper motor ($2K) and a few other sites. The Ford Racing crate motors are a bit too much $$$. So I would say that my budget is somewhere around $1500-$2000 for the whole engine, since I need to save some cash to redo the tranny and axle gears.
rockdawg84
04-15-2014 02:01 AM
MRStace84
11-14-2012 08:29 PM
jbulson
03-11-2003 09:12 PM
