1978 - 1996 Big Bronco
I need a driveshaft
Old 11-07-2005, 11:46 AM
solidpvc
solidpvc is offline
solidpvc is starting off with a positive reputation.
I need a driveshaft
Does anyone know where I can get a new driveshaft for a good price? I have a 1990 FSB 302 with E40D. It's the rear driveshaft with the double cardon (sp?). The centering ball stud/socket grenaded and the local Machine shop wants $290.00 if i need a new cv head. I'm sure I do, I've been driving it the way it is for over a month, it's my dd and I can't do with out. I have to buy a new driveshaft and then take the old one apart and see if I need the cv head. if not, I can buy the kit and do it myself, if so, i'll just junk it.
Thanks,
Solid.
Old 11-07-2005, 11:56 AM
muckypaws's Avatar
muckypaws
muckypaws is offline
muckypaws is gaining momentum as a positive member of FTE.
you can get all the replacement parts to rebuild it from many places including bronco graveyard. Its not a huge job to do if you have a good vice to hold the damn thing as they are so heavy.
Old 11-07-2005, 12:01 PM
solidpvc
solidpvc is offline
Yep, I found the kits and I've seen a writeup on how to replace it, but i'm pretty sure the centering stud is shot. If so, I will have to have a machine shop cut off the old cv head and weld on the new one. The local machine shop is a joke IMO. Since it's my daily driver, I have to replace the driveshaft first. If it were just the U joints it would be no problem, i can change them all day, I'm just worried about the centering stud.
Old 11-07-2005, 12:02 PM
solidpvc
solidpvc is offline
And it looks like I will be getting the shaft from JBG.com.
Old 11-07-2005, 12:12 PM
InkDawg
InkDawg is offline
InkDawg is starting off with a positive reputation.
The centering ball is not hard to replace...you can get it from Napa...
Old 11-07-2005, 05:47 PM
bossind's Avatar
bossind
bossind is offline
bossind is starting off with a positive reputation.
He said the stud was NFG.
Old 11-07-2005, 06:11 PM
elmotho
elmotho is offline
elmotho is starting off with a positive reputation.
I was looking into this once. Found a place called Mountain Driveline back home in AZ. They have a web page. Do a google search. Prices looked good. Just a thought.
Old 11-08-2005, 09:16 AM
solidpvc
solidpvc is offline
Thanks for the help guys.
Elmotho, the prices look good. I will probably get it from them.
Solid.
Old 11-08-2005, 09:26 AM
FS88Bronco
FS88Bronco is offline
FS88Bronco is starting off with a positive reputation.
If the smooth surface of the stud has been scarred badly from wear or abuse, replacing the joint will only destroy the needle bearings in the replacement part. The yoke at front of driveshaft must be cut off squarely and a new one welded on. Then the complete assembly should be balanced for smooth operation before re-installing. Auto Zone listed the driveshaft assembly in their computer system, but the store manager said none were available, even by special order. He recommended a local driveline shop, where he had personal work done in the past. The shop performed a complete rebuild in less than 24 hrs, for around $300.
Old 11-08-2005, 09:44 AM
InkDawg
InkDawg is offline
I didn't say anything about a stud...read what I wrote...sorry if I don't know french...
Old 11-08-2005, 05:05 PM
bossind's Avatar
bossind
bossind is offline
I didn't say you did I was saying that he (SOLIDPVC) said the stud was NFG (No f*** Good) perhaps you should take the time to read what he wrote, anyway because of the bad stud the kit you recommended would not work.
I don't understand french either but what does that have to do with anything?
Old 11-11-2005, 01:27 PM
solidpvc
solidpvc is offline
Thanks for the help guys. I got the driveshaft ordered.
Thanks
Solid.
40dog
06-07-2017 06:47 AM
little.dude
02-04-2016 07:20 PM
HMA-169
22
12-17-2004 01:34 PM
mitchntx
07-25-2002 07:18 AM
Quick Reply: I need a driveshaft
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
