Brake troubleshooting..
79 F250, 4x4, dual piston calipers, 2 1/2" wide rear shoes. The brakes never worked when I bought the truck. Had a pedal when the truck was off, start it up, and straight to the floor. Well we found that, brake line was spewing. Well, got new shoes/pads on the truck, new MC (thought that is what the problem was before i found the leak). The shoes are adjusted perfectly, have checked and rechecked and checked again(too tight if anything now). I can't find any more leaks, and the level in the MC doesn't drop.
My problem now is that when you hit the brakes, you have to pump them up 3 times or so before you get a pedal. The first couple times it goes straight to the floor, then it firms up. Let it sit for 30 sec or so, and it goes right back to it.
If you stand on the pedal (and it doesn't die, but thats a whole other problem), the pedal doesn't fade. It stays firm and about 1/3 of it's travel.
I've bled everything as much as humanly possible.. Cept for the LR wheel cylinder, bleeder is broke off, but bled it at the brake line fitting. (thats where the leak was to begin with). The wheel cylinders aren't leaking.
What else is there? I bench bled the MC before it was put on, but is possible i screwed that up I guess. ?? Any suggestions?
Matt
Take the cap off the M/C and see if there is any bubbling in one of the reservoir's when this happens.
It is still probably a bleeding problem.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3180&.jpg
http://community.webshots.com/user/mil1ion
[font color=green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
One other thing I can think of right now is bad/soft flex lines to the front calipers. If they are real bad they can buldge out and feel a lot like air as the line expands. Only seen this once or twice....but I guess a third time isnt to hard to beleive
Sparky
Got there by putting the old MC back on after bleeding the heck out of it, and putting on new wheel cylinders.
I think alot of it has to do now with bad hardware (springs) in the back cuasing the shoes to change adjustment after you adjust them out...
We ended up having a BAD vibration after 50mph also.. The driveshaft was the wrong length.. That sucked, had to have it retubed at $160..
Then, getting the distributor unstuck (hammers and pry bars.. and then a new dist)..
Well, it runs now.. Not decently, the carb is shot, but it can be driven back and forth to work!
