Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
air hammer
Old Nov 2, 2005 | 12:16 AM
someday's Avatar
someday
air hammer
i dont have much experience with air hammers, except a cheap one from harbor freight...so far i haven't had much luck with it, but maybe i would have better results with a better quality product. the problem is how can you tell which is better and powerful? the only specs i can find are bpm or stroke. what is the best combo or models?
Old Nov 3, 2005 | 11:11 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I've never been able to figure them out either. I've got a long barrel Snap On that usually has better luck in somebody else's hands.
I usually don't pull it out unless it's my last resort though.
Old Nov 4, 2005 | 09:41 AM
oldhalftons's Avatar
oldhalftons
air hammers need lots of air, about 11 cfm to really rip into something.
Old Nov 4, 2005 | 10:18 AM
someday's Avatar
someday
that makes me feel a little better
could running it at 125psi instead of the recommended 90psi actually hurt performance...i have a 25g craftsman 3.5 hp 175psi compressor that delivers 5.1cfm@90psi
i will stick with what i have until i figure out what the problem is: me, air compressor, air hammer, air hammer accessories, or anything that i might be forgetting
thxs
Old Nov 4, 2005 | 10:21 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
Check the max torque ratings. If it's not given, don't buy.
Old Nov 4, 2005 | 11:17 AM
someday's Avatar
someday
i dont think air hammers are torque rated
Old Nov 4, 2005 | 12:35 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
OOps. my bad - I was thinking of impact wrench -
Old Nov 4, 2005 | 12:36 PM
dwoodler's Avatar
dwoodler
I found that unless I really leaned on mine that it didn't work worth a darn. So when I'm air hammering, I brace whatever I'm working on, then put all my weight on the air hammer and hit the trigger. I do 5 to 10 seconds bursts and never use it once the compressor has kicked on. The last time I used it, it took a pretty good chunk outta the floor when I slipped off the nut I was cutting off and hit the cement with it! ;-)
BTW - mine's a $19.00 CAD one from princess auto (like harbour freight I think)
Old Nov 4, 2005 | 05:44 PM
OSin86's Avatar
OSin86
I'll never buy a cheap one again. I've had a couple of the cheap-o's and they don't even compair to a good IR.
Old Nov 4, 2005 | 07:56 PM
sierraben's Avatar
sierraben
Let the hammer do the work, not you.
Old Nov 4, 2005 | 11:08 PM
Bdox's Avatar
Bdox
Buy a Chicago Pneumatic. I have had several other brands and none lasted a year, or they were too intolerable to find out how long they would last. There are probably some other good brands but I have had my CP for over thirty years and it has great power and is very controllable. Look for a long stroke. Long stroke equals big impact. Also go for lower bpm because when the operate too fast they are more difficult to control and the faster ones tend to peen rather than drive. Also, buy high quality tools (bits) for them. Keep the tools clean and ground to their proper shape. Oil your air hammer with air tool oil or ATF
Old Nov 5, 2005 | 09:57 AM
fixnair's Avatar
fixnair
Bdox has some good advice. One more thing though, and this goes for any air hammer, even a jackhammer or paving breaker. Do not allow the thing to run without applying pressure to the cutting point. This allows the internal piston to go fully forward and striking the nose of the cylinder rather the tool. This will soon break the piston or cylinder. Always release the trigger when removing the tool from the work.
They also use lots of air and appropriate size hose is a must. It should work well at pressures any where from 60 to 150 PSIG.
Old Nov 5, 2005 | 06:12 PM
someday's Avatar
someday
bdox, which cp model do you have?
i figured that longer stroke with less blows meant it was packing a bigger punch. my hammer reminds me of a small dog with a lot of bark but no bite. i am looking for something economical, somewhat compact to get into tight spaces, and still pack a punch. similiar to the IR2135QTi impact gun that i just bought. cant wait to see what that thing can do.
thanks for all the advice
Old Nov 5, 2005 | 06:48 PM
cficare's Avatar
cficare
Mine's been real handy for cutting welds. If you're real good, you can also chip a bevel for weld-prep in lieu of grinding.
BTW ... it's a cheapie from Northern Hyd.
Old Nov 5, 2005 | 07:31 PM
Bdox's Avatar
Bdox
Air Hammer
Hi Someday,
My air hammer is a CP716. CP's name for it is "Zipgun."
It is not exactly compact. I installed one of those aluminum retainers instead of using the spring type retainer, and with that in place it measures about 10 inches fore and aft. But this thing is in a different league from the others that I have used. As I became accustomed to it I learned to use it for things that I had never thought of.
