1978 - 1996 Big Bronco
Bronco 96 with 351 Losing Power
Old 11-01-2005, 08:44 AM
SuperBlue's Avatar
SuperBlue
SuperBlue is offline
SuperBlue is starting off with a positive reputation.
Unhappy Bronco 96 with 351 Losing Power
My 1996 bronco with a 351 started cutting out on the way to work, couldn't keep the RPM's over 1100. Replaced my fuel filter, blew thru the old one and it didn't seem obstructed, didn't get a chance to test drive it after the filter due to beers and halloween. Any ideas where else to check next? Not getting a check engine light, should I check for error codes even without check engine light off? Possible water in gas? Cats clogging? EFI? Fuel pump? What do I need to check fuel pressure at the rails? Any help would be greatly appreciated, won't be able to start troubleshooting until tomorrow. Thanks.
Cheers!
Old 11-01-2005, 09:09 AM
muckypaws's Avatar
muckypaws
muckypaws is offline
muckypaws is gaining momentum as a positive member of FTE.
I'd always start with the codes first - they can point you in the right direction without wasting time guessing what else might be wrong. If the codes are clear then its back to the drawing board and checking pressures/ connections/ flow etc.
Simon
Old 11-01-2005, 10:11 AM
SuperBlue's Avatar
SuperBlue
I will check for codes tomorrow. Thanks.
Old 11-01-2005, 11:10 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
replace the filter anyways. just because you can blow thru it means nothing. Codes are also important. it will still store them even with no light. when was your last tune up on this? might be time for plugs/cap/rotor and possibly new wires. just run regular copper autolites or motorcraft plugs. none of that fancy platinum ones.
Old 11-01-2005, 11:16 AM
SuperBlue's Avatar
SuperBlue
New filter is in and the old in the can, it got new dis cap/rotor and champion truck plugs 8k miles ago. I initially put some bosch platinum tips in and she ran like crap, gas mileage went to pot too, i guess not enough current going thru those little platinum tips. Truck has got about 140K miles now. You're the second person that said just because you can blow thru the filter doesn't mean it is good. I will give her a test drive tonight. Thanks for the input!
Old 11-01-2005, 11:18 AM
Kemicalburns
whats your timing set at as well. and how old are the plug wires?
Old 11-01-2005, 11:24 AM
SuperBlue's Avatar
SuperBlue
Not sure about the timing, never have checked it since new. Plug wires are all original and should be changed, but, haven't got to it yet, maybe nows a good time.
bhplumber
6.7L Power Stroke Diesel
11-18-2013 08:13 PM
Scaper
04-28-2012 06:37 PM
great8
Ranger & B-Series
11-02-2010 09:43 PM
gov2mod
44
02-24-2008 06:16 PM
4WDBronco
23
10-08-2004 02:05 PM
Quick Reply: Bronco 96 with 351 Losing Power
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
