Oil & Lubrication
ATF in 95 E4OD PSD
Old Oct 27, 2005 | 10:33 AM
Dustin_86's Avatar
Dustin_86
Question ATF in 95 E4OD PSD
I'm changing the trans fliud in a buddys 95 F250 PSD E4OD this weekend. What kinda of fluid does the E4od take? How much like 20Qts -just the pan? How much for the converter?
I'm thinking just the pan but may do the conveter as well.
I will use my car to get extra fluid if he does not get enough.
Dustin
How much fluid for the rear diff?
it is posi so additive is a must.
Old Oct 27, 2005 | 11:03 AM
jimandmandy's Avatar
jimandmandy
Mercon, not Mercon V for the E4OD. It has about one gallon in the pan and almost four gallons total when you drain the converter. Total refill capacity is about 14-15 quarts. Mine was a 4x4, the 2wd one might vary slightly.
The rear diff only needs additive if there is an "H" in the axle code on the door post sticker. 8 oz for Ford Sterling 10.25 axles, 4 oz for Dana axles. Both the Ford 10.25 and Dana 60 take just over 6 pints of 80W-90 conventional or 75W-140 synthetic.
Jim
Old Oct 27, 2005 | 12:00 PM
Casey's Avatar
Casey
Before changing the trans fluid read this:
https://www.ford-trucks.com/article/...nsmission.html
Changing just the fluid in the pan is a waste of time and money. You won't even get half of the total changed, so why bother? Either drain the pan and torque converter or use the instructions above.
