1948-1960: 1949/1950 VIN # Cut off
#661
#662
#663
The break between 49 and 50 is what we've been trying to establish with all this. The dividing point appears to be somewhere between 280,000 and 300,000.
We can't get closer than that due to:
1. incorrect reporting by some guys on ebay who see the 9 and assume it must mean 49.
2. All states title differently. Back then a truck wasn't processed thru the system of some states until it was sold, so a dealership could have an early 49 that didn't sell until late 1950 and it would be titled as a 50....even tho it had an early 49 serial number.
#665
#666
Early 1950 missing glove box plate
has the early bed on it, but also came with a late 50 bed. Still have to identify engine it is a flathead 8 but I don't think the oil pan is correct (has a removable plate in the bottom of it.) and there is another flathead motor in pieces in the garage. Also had a late 50 bed that came with it.
98RC300272 (has 2 letters after the vin, will have to post those later)
#667
Check your firewall for a build code.
#669
This website from the flathead forum might be interesting to you. Scroll down about half-way and you'll see the oil pan selections. It's a pdf file so it might take a bit to load.
http://www.flatheadv8.org/bellhousing.pdf
#671
The serial number (vin) tells you most of what you know. 1949 226 six cyl half-ton
270174 is the serial number.
Please re-check the firewall. I think it should be P 2 NR ?(6)B 3378
P was a prefix used only by the Norfolk assembly plant
2 is Vermillion Red
NR Norfolk plant - no similar plants ended in F
date code - your 'C' should be a number, the B is February production
3378 is plant code for vehicle down the line
Hope this helps
Tim
2 is Vermillion Red
Hope this helps
Tim
#673
#674
This Panel Truck was an ex-US Army National Guard from PA
1 - Year truck is registered as (or believed to be) 1951
2 - VIN # (The whole thing including the 98RC, 98RD, etc.)-F1R1EG27392
3 - Bed - Raised Panel or flat panel- Panel Truck
4 - Is this the original bed
5 - Transmission- 3spd Light Duty
6 - Column shift or floor shift- Column
7 - # stamped into the firewall if you have one.- None
Vehicle beyond repair - scrapped
