1948-1960: 1949/1950 VIN # Cut off
Old 05-09-2017, 10:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Wasn't the Norfolk plant in California ?
  #1127
Old 05-09-2017, 11:05 PM
mtflat's Avatar
mtflat
mtflat is online now
No, you're thinking of Richmond, which was in CA.
I had to catch myself earlier, wondering how that truck got so far from home
  #1128
Old 05-10-2017, 03:40 PM
Spigot1996's Avatar
Spigot1996
Spigot1996 is offline
Thanks!..
"14F - assembled June 14, 1951 <probably> (Ford used this old serial string until Sept 15, 1951)"
Did they really assemble a '50 truck in '51?
ed
Originally Posted by mtflat
Not much by the serial number but the firewall stamping is helpful.
1950 V8 Half-ton, serial number 410867
firewall:
P - I don't know, but Norfolk is the only assembly plant that included this extra letter
A - color Raven Black
NR - Norfolk, VA assembly plant
81 - vehicle down the line
  #1129
Old 05-10-2017, 03:54 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
firewall:
The ONLY place I have seen that reference is on the LMC website and catalog, it is NOT AT ALL TRUE.
  #1130
Old 05-10-2017, 06:37 PM
mtflat's Avatar
mtflat
The data shows that LMC is probably right. I've seen the reference a few other places too.
  #1131
Old 05-10-2017, 06:45 PM
harleymsn's Avatar
harleymsn
Have you ever actually seen a 1951 truck with the 49-50 sequence. I have not. Now my 51-52 database isn't as large as this one here, but NONE have that sequence.
  #1132
Old 05-11-2017, 10:54 AM
ALBUQ F-1's Avatar
ALBUQ F-1
LOL, you're right, just a senior moment I guess!
  #1133
Old 05-13-2017, 12:25 AM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Well, I just finished putting all this in a spreadsheet. and now I would like to fill in information. I would like to find out more information about these trucks.
I'm looking for information to put with each vehicle serial number (later named VIN);
  1. Branch information (can be found on the Patent Plate on passenger side of firewall the second is stamped into firewall?
  2. Heaters: Fresh air or cab air system?
  3. Cigar / cigarette lighter?
  4. Dome Light?
  5. Arm Rest?
  6. Also large trucks: Who has PTO? What's it run (Winch, Hoist, Dump bed, Auger or a power shaft)?
  7. Dually rear wheels?
  8. 2 speed rear end?
  9. Trans brake?
  10. Those with trans brake, Does the PTO work when trans brake is on?
  #1134
Old 07-31-2017, 11:00 AM
acl9865's Avatar
acl9865
acl9865 is online now
I was doing more research on my 98RTL VIN with 226 that appears factory..
Came across this old listing for V8 F4 with 98RTL VIN also.
1950 Ford F4 Base 3.9L for sale: photos, technical specifications, description
  #1135
Old 07-31-2017, 09:19 PM
mtflat's Avatar
mtflat
I guess I don't know all your history of info, but 98RTL should indicate a 239 V8 as in the link posted.
The 226 I6 was set up differently - battery and starter solenoid on the driver's side.
Is that what you have? If so, it's quite possible your truck should have serial prefix of 97HTL and was mis-stamped.
  #1136
Old 10-01-2017, 10:13 PM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Gertie-The '49 F2 is offline
Thought I would post to this thread so as to keep it up in the more recent pages, and to double check my data entry to make sure it was correct. This way, any new owners can register their trucks if they so desire. Also to keep Moe busy with his database.
  #1137
Old 10-02-2017, 06:45 PM
Moe Craig's Avatar
Moe Craig
I read my firewall stamp 2 DL D 11 over 2012
Worked on my FW some today. I found my FW Stamp for those that are trying to do a data base of this information. But first my serial # again is 98RC179143. The brake down of the FW Stamp
2 DL D 11 - 2012
2 = Vermillion Red
DL = Dallas
D = April
11 = 11th Day
2012 =
the funny thing to me is that Bobbytnm (found his info on post #35) was born after mine by a month but his last 4 numbers are 1008 lower than mine.
  #1138
Old 10-09-2017, 11:34 AM
BoerneF1's Avatar
BoerneF1
BoerneF1 is offline
Vin Number Help
I have purchased a what was believed to be a 1950 Ford F5 American LaFrance Fire Truck. The title is lost and am in the process of getting a bonded title.
Here is the Vin Number.
88RT-97146
I believe what I am reading here it is a 48 is that correct?
  #1139
Old 10-09-2017, 05:05 PM
harleymsn's Avatar
harleymsn
88RT-97146
Yes, it would be a 1948
8= 1948
8R= 239 cu in V8 flathead
T= F5
1949 & 50 would start with a 9
  #1140
Old 10-09-2017, 05:08 PM
BoerneF1's Avatar
BoerneF1
BoerneF1 is offline
8= 1948
T= F5
Thanks for the confirmation!
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
