1948-1960: 1949/1950 VIN # Cut off
#1036
#1037
There is certainly no "kit" that will give you a VIN for your truck. New, aftermarket frames should come with a Manufacturer's Statement of Origin (MSO), just like any new car, that proves its legit origin. You take that paperwork, along with your current vehicle title and your completed truck to a DMV or State inspection site and they will look over the documentation, make sure nothing is stolen, and either transfer your current number to the replacement frame, or issue you a totally new number. Your state authorities are the only ones legally allowed to stamp frames or issue VINs. Do not attempt this at home.
#1038
You can buy stamps or punches with all the alpha-numeric characters, but I thought custom frames came with a serial number. Ford has, for years, used the fame as their primary serial number location, so, the new frame would create a new serial number.
I did a quick search and this has been the topic of discussions on a couple of sites. I did not, however, see a solution. I would contact the local DMV for their guidance.
Looking at the TCI site didn't offer much help either.
I have to agree with Wayne and should have cautioned, do not try to create or place your own serial number.
#1039
Gertie The '49 F-2
Here is my contribution to the database.
!949 Ford F-2
Serial #98 RD 207319
Branch HP (Highland Park)
Frame and VIN numbers match.
Firewall codes are indistinguishable, or non-existent. However, given the long period of ownership by the family (46+ years), and low mileage since first purchased, the following can be assumed as original:
Single wiper and visor.
Magic Air heater.
239 V8.
HD 3-spd transmission.
Meadow Green paint finish.
Brown upholstery.
Attached is a copy of my original title from 5/13/1983. This is a Correction title, as the BMV screwed up an earlier one from January or February of the same year. This seems to be a habit of Indiana's Bureau of Motor Vehicles. Two years ago, I had to apply for a lost title, as the one in the photo could no longer be accepted. Seems some moron mis-entered the year of manufacture when the state went to a computer database, and had the truck listed as a 1979. So now, I have TWO titles for the same truck. At least I can definitively prove I own it.
!949 Ford F-2
Magic Air heater.
239 V8.
Brown upholstery.
#1040
#1042
#1043
I'm selling this 48 F2. The serial number on the metal tag on firewall matches the frame stamp. I can't really read the rest of the tag as the black is washed off.
Any help decoding this appreciated. Ser.# 87HY165645
The firewall stamp is weird. First character looks exactly like a backwards 3 then HP23K.
After reading enough info I'm thinking 8 for 1948, 7HY for 226 and which one off assy line?
I found a flat 6 and trans from a 48 for sale. I'd like to get rid of the Old's V8 that's in it.
Scott
#1044
Scott
7H= 226 Flathead 6
Y= F3
That backwards 3 could actually be a 3 that was stamped upside down, if so
3 = Black
HP = Highland Park
23K = October 23
#1045
Thanks Joe,
So it's an F3? Weird because other than the engine swap it doesn't look touched.
It has F2 badges, 16" Innies with hub caps, and rear shocks. Does NOT have the 14" rear drums. Also evidence it was column shift.
I don't know the original owner other than he was a rancher on outskirts of Tucson. The second owner got it when he got out of Viet Nam and it has sat ever since.
Scott
Scott
#1046
Thanks Joe,
Scott
Scott
#1047
#1048
#1049
Ross, you are exactly right. The floor plate is out and I saw the anchor for a shift tube or whatever it is. I found the floor plate halves and there is no opening for column shift parts.
I'm pretty sure it is an F2. The battery tray is on driver side which made me think six cyl from the get go. So that makes sense.
I originally thought Meridian Blue but now that bed is off I can see it was Raven Black for sure.
It has the E-brake lever under the dash so it didn't have the trans mounted brake. It still has the linkage under the bed with cables to the backing plates.
No doubt in my mind now that it is an F2. Thank you guys for the info.
Scott
Scott
#1050
Well, for our first post, we've already learned something today!
We thought we bought the cab & chassis to a Ford 1949...Series F1
On the plate in the glove box it says,"Engine No.98RC- 496514 /Model 9RC
Joe says, "From that number it appears to be a 1950 F1, sequential number 496514."
He said to come to this forum to find out where we look to find the original color and what plant it was manufactured?
We may not have many truck parts to look thru but where do we look first?
Thanks!!!
Thanks!!!
