1948-1960: 1949/1950 VIN # Cut off
#976
hi guys. havn't been on for a hile but all of that might change since we just got from picking up a new f1 project truck
the previous owner tells me its a 1950 and has a good backstory knowing the original owner.
after reading through these posts i am now quesioning the year
could someone who knows please let me know if its a 50
thanks in advance
thanks in advance
- VIN - 98RC 264218 HP
- Raised panel bed
- Original steel floor in bed
- 3 speed on floor
- Firewall # only could make out 17J243
- color original red
- rear diff has rear cover
- small rear window
#977
thanks in advance
thanks in advance
- Raised panel bed
- 3 speed on floor
- small rear window
I've cataloged over 900 trucks and have 21 with HP stampings so Highland Park MI seems to be normal. If your truck was red the rest of your firewall stamping would read 2HP17J243 or EHP17J243. HP looks like one of the earlier plants to switch to a letter for color code.
#978
It's entirely possible that a truck built mid-Sept could sit on a dealer's lot for a couple of months. Some localities titled in the calendar year of purchase, not manufacture. If your title is clear and lists it as a 50, you're safe calling it a 50. Nothing of any consequence changed during those two model years anyway.
#979
so here is the thing, we don’t have a title, I’ll need totell the DMV what year.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
So what should i choose and what would be the reasoning/ benefitif any at all?
also i looked on the frame and can not seem to locate the s/n
we looked on the drivers side frame top from the firewall to the frame horn and nothing, is it some where else?
thanks
Steve
#980
thanks
Steve
thanks
Steve
Steve, your serial number should be on the top of the passengers side frame
near the motor mount. They are not punched too deeply, so be careful removing any grime.
Here's where mine is located.
#982
#983
BD, your F5 is a very early '49
'48 went thru serial no 139262 for V8s, 166979 for 6s (according to oldfordtruckclub)
'49s picked up at those numbers
stangetr, if you're working to get a title I'd call your truck a '49
The vin appears 3 places: top of the frame rail as indicated above, the data plate on the firewall near the starter solenoid, and on the rating plate fastened to the glovebox door. It should have the same number all three places. The frame number is the only legal one for police inspection. All states differ in the process to get a title.
My info on vins is good only on 48-50s. Before and after that narrow window I only know bits and pieces. 51/52 could very well use HM in place of HP.
#984
#986
#987
I don't think you'll ever be able to know that for sure. There's too many undocumented trucks still in existence, and way too many that we could never account for on this forum. But mid-November is pretty late in production, so you have at the very least, one of the last ones built for 1950. Keep in mind, though, that there were a dozen plants cranking these out, and in 6 weeks there were thousands more built after yours.
#988
#989
2) Also I heard there is an interest in the rear windshield. The metal opening is 27.5 x 9.25 in. But I don't know if that is small or big.
Thanks
#990
3 is the code for Black
14L was the date it was assembled - 14 November
76B is in-house encoding specific to each plant. We don't know.
27.5" sounds like a small back window - the large one reaches from almost cab corner to cab corner and was used 51/52 although some plants might have used them for late 50s. It's one of the things we're trying to sort out. Height was the same for both. Thanks for your help
