1948-1960: 1949/1950 VIN # Cut off
#871
I Took another look at it This is what I got 7RHIIE574..I thought the 4 was a 1.. I was told this was a special order truck for the California Highway Dept. It was a F1 Body and Bed with a 3/4 ton suspension.
#872
Would be surprising if it was ordered by CHP and delieved from Highland Park, MI plant, unless that was the only plant that was building the '48 F1.
#873
#876
It tells us nothing you already don't know; year, engine, series, consecutive unit number. But if you see some letters following the vin stamped on the patent plate, found riveted to the upper corner of the firewall, that would tell you the build plant. If you see a group of numbers and letters stamped into the firewall itself somewhere near or about the upper center, that will tell you several more things. Post 'em if you got 'em.
#877
1949 F1 truck Vin
vin 98rc156821
Registered as 1949 Ford F1
Flathead V8 (vin in glovebox said 98rc141101 model 9rc)
4 spd on floor
Regular box with Wood running lengthwise
cco after vin number found on plate under hood....later I figured it was cgo (chicago build?)
what do you figure?
Thanks
4 spd on floor
what do you figure?
Thanks
#878
#879
From previous post for vin 98rc156821
letters looked like cco afterwards...but maybe CGO for Chicago Build
would production number suggest early 49?
plate in glovebox has engine vin 98rc141101 model 9rc
cannot find any numbers on firewall except plate that shows vin...
Thanks
Thanks
It has been documented that some plants didn't stamp firewalls, so it may not be unusual yours wasn't. It's too bad because among those numbers is a date code and a color code.
#880
I think you're on the right track with the Chicago build. Based on my limited knowledge from reading the posts here (there are others here that have compiled the data and have better records for these answers), I'd say your truck is of mid year production. It's interestiing that your glove box plate doesn't match your firewall plate. AFAIK, those numbers should match. You may want to search the tops of the frame rails under the hood for the stamped vin there. Start with the right (passenger) side. Hopefully one of them is right. Do you have a title, and does it match either of these numbers?
#881
#882
Two more to add to the database...
Mercury:
Engine - 9EE-973 (8 cyl/4 speed non synchro w/ reverse latch)
Trim - 16 (brown?)
Serial - MD83H49 - 28525 (1/2 ton, "home office", 1949)
Model - MD83 (1/2 ton, short bed)
Paint - 35 (Sea Mist Green)
Ford:
98RC-193777 (1949, 8 cylinder, 1/2 ton)
P3NP(?R) (Black, Norfolk?)
28F2762 (June 28th, 2762 sequence ?)
Raised panel original bed
3 speed floor shift
Ryan
Mercury:
Trim - 16 (brown?)
Ford:
3 speed floor shift
Ryan
#883
#884
If I'm reading that correctly, it says 1C KC 15J 49. And if it's correct, it's color code 1C, Kansas City assembly, production date 15 September, production code 49. That seems to blow a hole in Ross' theory that that particular number is the number of the particular series built at that plant during the course of the model year. I would think in 9 months, far more than 49 F6's would have been built. Unless someone can show me some kind of actual evidence, I believe the significance of that number has been lost to time.
#885
Are cowl stampings on 48-50's "the" serial number, or info that is in addition to it, like the color code?
Looking at Havi's cowl, I have to wonder how they stamped them. The cowl is badly distorted by the stamping, so done by hand on a completed cab with no backing? A really bad idea. Hard to believe that would even work.
