1948-1960: 1949/1950 VIN # Cut off
Old 12-19-2011, 08:55 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
First truck is likely a 51/52 with a 48-50 front clip and dash cut for the 48-50 cluster. Some PO likely pulled an old switcheroo with the data tags.
Second truck is a 51 that was made in Richmond, CA.
If it were me, I'd buy every useable piece from those trucks, within reason.
  #797
Old 12-24-2011, 12:16 AM
kcb37's Avatar
kcb37
kcb37 is offline
Well I have been asked to share so here ya go.
My truck is a 49 bought at a junkyard in Wamego KS, was on a rollback when I happened to see it. Bought it for 200 dollars. Biggest thing missing was the tailgate. The engine is siezed though.
My Serial number is in the 203 range, as I have read thru this thread well within the 49 year for a 6 cly.
I do have the raised bed pannels, however something I have run across seems like most bed floors (the metal part) had ribs much like a modern pickup. Mine does not, but the bed floor appears factory. I have had one member state there bed was also flat like mine.
I do not have the PS wiper (rubber plug) the PS visor has the metal punch out still intact, the serial number on the firewal and frame match, the plate on the glove box is gone.
Small rear window, 4 on the floor.
I know 3 of my rims are not stock, 2 are split rims, one has clips for a hub cap, one does not. So maybe none are stock, I have 16" rims on all 4.
The tag on the diff (still there) says 3.73's.
Stock mirrors were gone.
I had one tail light stock, believe the second added. Factory replacement light (not a Ford part but correct for the truck) the bracket however was a flat piece of steel.
Rear bumper is custom, so believe not stock rear bumper.
I have only the passenger side key lock.
My wood bed was "keyed" can't remeber what it's called now, ran across one member who said his was pieces of pallets.
An add on, my cowl vent is a two piece with 3 holes. Seems some were a two piece with no holes, some with, and some a flat piece if you will with a bracket.
My front leaf springs seem to be stock in line with either 8 or 9 can't remeber now. The rear however have 11 or 12 on the bottom and another 6 in an overload pack so neither one of those should be stock. The axle is a F1 axle so I believe it would be factory, could have been swaped though.
I had no radio, I don't believe I have the radio brackets, no antenna wire, or antenna hole in the body.
Standard trim.
Seems the standard trim had 4 clips to help hold the windshield in while the delux trim did not.
My grill is painted suggesting a later 49 model.
I cannot think of anything else that stands out now, had an add on spare tire carrier,and the rear bumper/hitch is welded into the frame. Going to be fun to cut out. Turn signals were added, expected.
I believe I have vac wipers, really haven't looked, but I have run across the option of vac or elec, could be wrong though.
I don't believe anything else was added to mine, other then the few add on's it appears 100& stock with excpetion of the rebuilt and sleeved engine which could be the factory engine.
Here are a few pic's to include the firewall stampings.
Raised bed.
Smooth bed floor
Hard to see but there are 3 holes in the cowl vent on mine, if you look close you can see one in the rust in the middle.
  #798
Old 12-25-2011, 01:33 PM
'49 F-1's Avatar
'49 F-1
'49 F-1 is offline
1949-1950?
*97HC*336918*CH
it's a 226 flat 6
has colume 3 speed
cowl # CHH 22L144B
also written on cowl pal grn
assume that palisad green
  #799
Old 12-25-2011, 01:52 PM
EAK69's Avatar
EAK69
EAK69 is offline
Mine:
*97HY*248276
I will have to look for the firewall stamping next time I am there.
I was told it had a straight 6 with a 3-speed, but someone noticed on one of the pics they think a V-8 was swapped in - but at the end of the day, there is no engine or transmission...
  #800
Old 12-25-2011, 03:02 PM
kcb37's Avatar
kcb37
kcb37 is offline
49f-1, If I remeber the "cutoff" no one has a definate cutoff, but it has been narrowed down considerably. Yours should be a 1950.
EAK, if you still have the origional battery tray I am pretty sure the 6 cly had the battery mounted on the drivers side like mine, and the V8 on the passenger side. That would be one clue.
But yours would have been a 6 from the factory.
  #801
Old 12-25-2011, 06:02 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,441 Likes on 1,390 Posts
Originally Posted by EAK69
Mine:
*97HY*248276
97HY decodes to 1949/50 226 6 cylinder F-3. Consecutive unit number in the 240,000 range should still be 1949, I believe. You'll have to find your firewall stampings to get any more details than that about your truck.
It was mentioned that it appeared someone put a flathead v8 radiator in your truck, since is looks to have two water necks in the upper tank. V8's used two rad hoses top and bottom, where the 6 only had one each. The flathead 6 cylinder from 48-51 had the battery tray over the steering box on the left side. V-8's and the new OHV 6 in '52 had the battery on the right.
  #802
Old 12-25-2011, 07:21 PM
EAK69's Avatar
EAK69
EAK69 is offline
The battery tray is on the drivers side - the guy who I got this from said it originally came with a 6, but as a few have pointed out - there probably was a V8 in there at one point, but regardless, there is nothing in there today!!
  #803
Old 12-25-2011, 08:31 PM
mtflat's Avatar
mtflat
mtflat is online now
Originally Posted by '49 F-1
1949-1950?
*97HC*336918*CH
it's a 226 flat 6
has colume 3 speed
cowl # CHH 22L144B
I can't explain all of your cowl stamping, but as noted in the serial number you have a 1950 half ton six cyl produced at the Chicago assembly plant.
Most Chicago plant trucks used a single number for paint color before the CH - such as 3CH or 7CH. I have one other truck noted like yours with the CHH beginning. CH would be for Chicago. Unless the H is for Palisade green, I don't know what it is.
Assembled 22 November (22L)
Vehicle designation down the line 144B
  #804
Old 12-26-2011, 03:59 PM
'49 F-1's Avatar
'49 F-1
'49 F-1 is offline
thanks for the info. I'm doing a frame off resto back to the way it came off the line. just need to do little more sanding then paint, then all back together. The flathead 6 turned over after sitting in a field for 38 yrs. (now thats ford tufff)
  #805
Old 12-28-2011, 07:34 PM
EAK69's Avatar
EAK69
EAK69 is offline
Here is a pic of the firewall (right in front of the passanger side seat) and I didn't get all the numbers in this pic - but wrote them down...
I do know the number is: I (or 1) C L B 2 5 X 2 C 4
Here is a pic of the glovebox plate:
  #806
Old 12-28-2011, 09:49 PM
52 Merc's Avatar
52 Merc
1C I believe should be your paint code, but I don't have that decode info.
LB is the Long Beach, CA assembly plant
25X is more likely 25K, which would be your build date, October 25, 1949.
That's all I know. ;-)
  #807
Old 12-28-2011, 11:49 PM
mtflat's Avatar
mtflat
10 is the paint code for Gray - which it appears to be
I agree with Wayne on the rest
2C4 is assembly code for the vehicle down the line - unknown (most assembly plants just used numbers) and given how this guy stamped the paint code, it might read 204 : )
  #808
Old 12-29-2011, 02:06 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Here is the information on my 1950 F2 V8 4sp. I think this is the latest VIN that I have seen on this thread but I admit that I did not read all 21 pages.
1 - Year truck is registered as (or believed to be) - 1950
2 - VIN # (The whole thing including the 98RC, 98RD, etc.) - Engine # on frame and glove box plate 98RD480988. The new Ford plate on the firewall above the starter relay reads G0820M932
3 - Bed - Raised Panel or flat panel - not original
4 - Is this the original bed - No
5 - Transmission - 4sp w/granny low non-syncho
6 - Column shift or floor shift - floor
7 - # stamped into the firewall if you have one - can't find one
The frame and cab appear to match although the plates have obviously been reattached so who knows?!? The cab has a small rear window. It looks like the new Ford VIN plate was issued perhaps by a state DMV(?) as that is what appears on the title.
I also found some interesting tags inside the seat back when I took it apart to be reupholstered.
  #809
Old 12-29-2011, 05:22 PM
52 Merc's Avatar
52 Merc
The seat tags are certainly an interesting find. Your glove box tag is original, and it's cool that it matches your frame number. If it's ever been removed, it was carefully put back as original, since that's exactly how an OEM install looks. The firewall tag is an aftermarket replacement. I don't know who would have stamped it or why your title would match that number. Every state I'm aware of has their own official vin tags they use when they have to issue a vin. They would not use a repro tag like that. My guess is that a vin was issued for some reason (probably due to a lost title or the fact it is an "assembled vehicle" constructed from parts of several different trucks) and that some previous owner had that tag made to match the new, state issued number. But you can say you have documentation to prove that at least part of your truck is 1950. ;-)
  #810
Old 12-29-2011, 05:49 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
That is nice to know that the glovebox tag attachments look original. I was just happy to find the hidden serial number.
Thanks,
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
