1948-1960: 1949/1950 VIN # Cut off
  #781
Old 11-22-2011, 09:11 AM
walt460
walt460 is offline
walt460 is gaining momentum as a positive member of FTE.walt460 is gaining momentum as a positive member of FTE.
OK, got some time to investigate this truck this morning. The firewall tag is there, and readable. It shows *98RC*343299*C8. The firewall just below the cowl vent has this series of letters/numbers; 4C3L2D388. I found the serial number on the passenger side frame rail, starting at the 2 large rivets for the frame corner brace. So far I can see the RC and the 343299 but not yer found the rest of the digits or the stars, got to get better access.
This truck is a floor shift, small window, and it does have the raised bed panels. It appears to have a factory heater.
Can you tell me the assembly plant, original color (has green paint in many places) and the cab build date?
Walt
UPDATE: the last three digits of the serial number are 229, not 299, sorry, my typo.
  #782
Old 11-22-2011, 05:45 PM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Walt
Hi Walt,
8's and 3's look a lot like "S" on these stamping so I'm giving it an educated guess here - on the serial number the C8 should read CS especially given the PA title.
I think the firewall code should read 4 CS L2 D388
4 is the color code and I have a note showing Chester PA plant using the 4 code for Meadow Green.
CS is Chester PA assembly plant
L2 is November 2nd
D388 is vehicle down the line.
I don't have much info for Chester built trucks - the ones I do have tend to be fleet or special use trucks. This is the first one with a firewall stamping so I'm grateful that you took time to post it.
  #783
Old 11-22-2011, 08:18 PM
walt460
walt460 is offline
Thanks for the info! You could very well be right about the C8 being a CS, and the C3 being a CS as well, it was cold out and raining when I was checking them numbers!
Built November 2nd.......but what year? 1949 or 1950?
UPDATE: You are correct, further cleaning has confirmed that both the firewall ID plate and the stamping on the cowl area show CS. Thanks!
  #784
Old 11-22-2011, 11:38 PM
mtflat
mtflat is offline
'50 as near as I can tell. Ford issued blocks of numbers to plants and some used them faster than others, so it's not an exact science.
  #785
Old 11-27-2011, 09:14 AM
walt460
walt460 is offline
F-1 on EBay
There is a 1949 F-1 truck on EBay today, selling as parts only, but he posted a photo of the firewall plate with serial number. It is 98RC205799, and being sold out of Lawton OKla.
The truck has raised panel bed, and a small rear window.
There is also a 1950 F-1 truck, 98RC455389, V8 truck, 3 speed on floor, flat-sided bed that seller claims is original to truck. Small back window. it is in Ottertail, MN.
And there is a 1949 F-2, serial # 98RD251666 listed for sale in Swaledale, IA, it is a V8 truck, floor shift, raised panel bed, small window.
Not sure if you want info like this, so please advise.
  #786
Old 12-02-2011, 11:25 AM
graygt07's Avatar
graygt07
graygt07 is offline
graygt07 is starting off with a positive reputation.
my vin? ???
I have a truck with a title that says 1950 and the vin # 98crc354199 but the body style is a 51. What is the deal? Thanks jeff
  #787
Old 12-02-2011, 01:41 PM
mtflat
mtflat is offline
What dash does your truck have? Front ends swap completely and many have over the years. I'd bet thats what happened with your truck, cause 51's weren't produced when it was built.
My 48 F1 had a 52 F1 deluxe front end when I bought it. Happened pretty often from the looks of things.
  #788
Old 12-02-2011, 01:44 PM
graygt07's Avatar
graygt07
graygt07 is offline
I have a 51 dash as well. I was wondering if that was the case but everything is 51 but the title
  #789
Old 12-02-2011, 02:36 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
harleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to behold
Is that the serial# from the frame? as well as the firewall and glove box tag?
Also, the first C should not be there. Is the box, the early(raised panel) or late model?
  #790
Old 12-02-2011, 04:19 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
As noted, it's common for parts to be swapped around on these old trucks. Have you verified the vin on the chassis with the title? The frame vin can be found on the top of the right side frame rail near the motor mount, looking down from under the hood. If that matches your title, then you've had a body swap. If it doesn't, you've been given a title to a different truck.
  #791
Old 12-02-2011, 08:03 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
51 or 52
Are we doing 51/52's?
Just bought a F-2 8ft Express
It looks like a 51 but the title shows a 52
Flathead 6, 4spd Crash Box
VIN: F2R2HM32955 (From glovebox door)
Runs, Drives, and Legal
  #792
Old 12-19-2011, 06:26 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Found two F1's in a wrecking yard today.
First has flat bed sides, big back window and 48-50 dash, front clip and floor shift. VIN on glove box is: 98RC-479431 Model 9RC.
Now that I look closer it appears that it is a 51-52 dash that has been cut for a 48-50 gauge cluster.
Second is a 51/52 with glove box VIN: F1R1RH-17032 and model 1RC.
Last edited by BigPigDaddy; 12-19-2011 at 07:19 PM. Reason: Add pics and VIN digit.
  #793
Old 12-19-2011, 06:55 PM
texan2004's Avatar
texan2004
texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
The first one is of real interest. I have heard of these 50's with big back windows and 448-50 dash but I've never seen one. If you are headed back out there I sure would love to get more information, especially the firewall stamping. Great find.
  #794
Old 12-19-2011, 07:07 PM
mtflat
mtflat is offline
Howdy Carl, I hope life has been treating you well. Nice to see your light on!
The first one has a 51/52 cab - or at least that dash. The trim line is clear around the radio area.
The vin is missing a digit - it needs six of them after the prefix.
I too would like to see what the chassis # is. Too many pieces missing to go by the glovebox door only (and it must be loose in the pile cause its not on the dash)
I'd call it a 51/52 with a 48-50 front end. Even possible the cab and box were replaced... thanks BPD, we learn something every time.
  #795
Old 12-19-2011, 07:14 PM
havi's Avatar
havi
havi is online now
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
I'm curious if the PO cut the dash to make a '48-50 instrument panel fit the 51/52 opening? Plus add the front clip? Like Tim says.
Secondly, that first truck looks to have 15" innie wheels on it.
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
