1948-1960: 1949/1950 VIN # Cut off
#781
Thanks for the info! You could very well be right about the C8 being a CS, and the C3 being a CS as well, it was cold out and raining when I was checking them numbers!
Built November 2nd.......but what year? 1949 or 1950?
UPDATE: You are correct, further cleaning has confirmed that both the firewall ID plate and the stamping on the cowl area show CS. Thanks!
#782
#783
F-1 on EBay
There is a 1949 F-1 truck on EBay today, selling as parts only, but he posted a photo of the firewall plate with serial number. It is 98RC205799, and being sold out of Lawton OKla.
The truck has raised panel bed, and a small rear window.
There is also a 1950 F-1 truck, 98RC455389, V8 truck, 3 speed on floor, flat-sided bed that seller claims is original to truck. Small back window. it is in Ottertail, MN.
And there is a 1949 F-2, serial # 98RD251666 listed for sale in Swaledale, IA, it is a V8 truck, floor shift, raised panel bed, small window.
Not sure if you want info like this, so please advise.
#785
#787
Also, the first C should not be there. Is the box, the early(raised panel) or late model?
#788
As noted, it's common for parts to be swapped around on these old trucks. Have you verified the vin on the chassis with the title? The frame vin can be found on the top of the right side frame rail near the motor mount, looking down from under the hood. If that matches your title, then you've had a body swap. If it doesn't, you've been given a title to a different truck.
#789
#790
Found two F1's in a wrecking yard today.
First has flat bed sides, big back window and 48-50 dash, front clip and floor shift. VIN on glove box is: 98RC-479431 Model 9RC.
Now that I look closer it appears that it is a 51-52 dash that has been cut for a 48-50 gauge cluster.
Second is a 51/52 with glove box VIN: F1R1RH-17032 and model 1RC.
Last edited by BigPigDaddy; 12-19-2011 at 07:19 PM. Reason: Add pics and VIN digit.
#791
#792
Howdy Carl, I hope life has been treating you well. Nice to see your light on!
The first one has a 51/52 cab - or at least that dash. The trim line is clear around the radio area.
The vin is missing a digit - it needs six of them after the prefix.
I too would like to see what the chassis # is. Too many pieces missing to go by the glovebox door only (and it must be loose in the pile cause its not on the dash)
I'd call it a 51/52 with a 48-50 front end. Even possible the cab and box were replaced... thanks BPD, we learn something every time.
#793
#794
Texan,
You're not gonna believe this, but here's another one of those hanging around on ebay. One of the members noticed it a few months ago, and it caused a big discussion. Everything fits to be the "unicorn", but some members finally just wrote it off as having its back cab panel replaced. Possibly after a wreck a LONG time ago. But I'm not so sure.
Ford : Other Pickups Ford : Other Pickups | eBay
#795
