1948-1960: 1949/1950 VIN # Cut off
#1126
#1127
#1128
Thanks!..
"14F - assembled June 14, 1951 <probably> (Ford used this old serial string until Sept 15, 1951)"
Did they really assemble a '50 truck in '51?
ed
ed
Not much by the serial number but the firewall stamping is helpful.
1950 V8 Half-ton, serial number 410867
firewall:
P - I don't know, but Norfolk is the only assembly plant that included this extra letter
A - color Raven Black
NR - Norfolk, VA assembly plant
81 - vehicle down the line
firewall:
#1129
firewall:
firewall:
#1130
#1131
#1132
#1133
Well, I just finished putting all this in a spreadsheet. and now I would like to fill in information. I would like to find out more information about these trucks.
I'm looking for information to put with each vehicle serial number (later named VIN);
- Branch information (can be found on the Patent Plate on passenger side of firewall the second is stamped into firewall?
- Heaters: Fresh air or cab air system?
- Cigar / cigarette lighter?
- Dome Light?
- Arm Rest?
- Also large trucks: Who has PTO? What's it run (Winch, Hoist, Dump bed, Auger or a power shaft)?
- Dually rear wheels?
- 2 speed rear end?
- Trans brake?
- Those with trans brake, Does the PTO work when trans brake is on?
#1134
I was doing more research on my 98RTL VIN with 226 that appears factory..
Came across this old listing for V8 F4 with 98RTL VIN also.
1950 Ford F4 Base 3.9L for sale: photos, technical specifications, description
#1135
I guess I don't know all your history of info, but 98RTL should indicate a 239 V8 as in the link posted.
The 226 I6 was set up differently - battery and starter solenoid on the driver's side.
Is that what you have? If so, it's quite possible your truck should have serial prefix of 97HTL and was mis-stamped.
#1136
#1137
I read my firewall stamp 2 DL D 11 over 2012
Worked on my FW some today. I found my FW Stamp for those that are trying to do a data base of this information. But first my serial # again is 98RC179143. The brake down of the FW Stamp
2 DL D 11 - 2012
2 = Vermillion Red
DL = Dallas
D = April
11 = 11th Day
2012 =
the funny thing to me is that Bobbytnm (found his info on post #35) was born after mine by a month but his last 4 numbers are 1008 lower than mine.
#1138
#1139
8= 1948
8R= 239 cu in V8 flathead
T= F5
1949 & 50 would start with a 9
