1948-1960: 1949/1950 VIN # Cut off
  #1051
Old 02-06-2016, 04:04 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Scotty's 52 F3 is offline
Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.
Ross, you are exactly right. The floor plate is out and I saw the anchor for a shift tube or whatever it is. I found the floor plate halves and there is no opening for column shift parts.
I'm pretty sure it is an F2. The battery tray is on driver side which made me think six cyl from the get go. So that makes sense.
I originally thought Meridian Blue but now that bed is off I can see it was Raven Black for sure.
It has the E-brake lever under the dash so it didn't have the trans mounted brake. It still has the linkage under the bed with cables to the backing plates.
No doubt in my mind now that it is an F2. Thank you guys for the info.
Scott
  #1052
Old 02-15-2016, 04:46 PM
RossVivona
RossVivona is offline
RossVivona is starting off with a positive reputation.
Well, for our first post, we've already learned something today!
We thought we bought the cab & chassis to a Ford 1949...Series F1
On the plate in the glove box it says,"Engine No.98RC- 496514 /Model 9RC
Joe says, "From that number it appears to be a 1950 F1, sequential number 496514."
He said to come to this forum to find out where we look to find the original color and what plant it was manufactured?
We may not have many truck parts to look thru but where do we look first?
Thanks!!!
  #1053
Old 02-15-2016, 07:00 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
harleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to behold
Thanks!!!
OK, for the build date, plant and color you need to look for the stampings in the firewall. They were not all stamped in the same location, sometimes it varied depending on which plant.
Patent plate pass side firewall note plant indicated on the right side (branch)
Firewall stamping
Serial number location on the frame
Frame Serial Number
  #1054
Old 03-05-2016, 12:46 PM
MKO
MKO is offline
MKO is starting off with a positive reputation.
F2 or F3?
Hello all, I have a "49" that is badged as an F3.
The firewall has 7H*172099* RIC
The glove box is 97HD 172099 model 9HD with a GVW of 5700
The rims are one piece 17 inch
The trans is 4 speed
The engine is a 6 cyl # 7HA 6015 B
The bed is 8 feet
The rear axel is double cone at the rims
My question is, is it an F2 with upgrades or an F3 with the wrong glove box plate?
I am pretty sure it is original and that I am the second owner.
It came out of Northern Ca.
Any help will be greatly appreciated.
Kevin
  #1055
Old 03-05-2016, 03:17 PM
harleymsn's Avatar
harleymsn
The bed is 8 feet
Kevin
The FIRST question ... what is the serial number stamped in the frame?
Both f2 & F3 had 8' box
If you have 17" wheels, they are NOT one piece, they are widowmakers.
F2 came with 8 lug 16" wheels, F3 came with 8 lug 17" wheels.
  #1056
Old 03-05-2016, 06:59 PM
MKO
MKO is offline
The rims are 8 lug 17"
They are not the common split rims and have a standard 8 lug center disc.
They do seem to be two piece when viewed from the backside.
The frame # is; 97H 172099
Kevin
  #1057
Old 03-05-2016, 10:29 PM
harleymsn's Avatar
harleymsn
Kevin
The widow makers are not a split ring rim, they actually split in the middle of the rim under the wide band.
Check the size of the rear brake drums
F2 would have a 12" dia. drum
F3 would be 14"
  #1058
Old 03-06-2016, 01:52 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The bed is 8 feet
Kevin
We've seen several model stamping errors on F2/3 trucks over the years. More common on the earlier models. I'd say you have an F3 that has F2 tags, which may have confused the stamp guy when he saw F3 specs, and put a * where the letter was supposed to go. Stranger things have been known to happen.
RIC is the code for Richmond, CA, assembly.
  #1059
Old 03-06-2016, 03:25 PM
MKO
MKO is offline
Thank you for that.
I don't think the truck has been out of California. It came with the registration papers up til they changed from having them visible on the steering column in the 60's.
Registration was always same owner and address in Arcata, Ca.
  #1060
Old 04-01-2016, 09:14 PM
dmvgal
dmvgal is offline
dmvgal is starting off with a positive reputation.
I've been searching for 5 days! I need to know before tomorrow
is this vin a 1949 or 1950 ford pick up?
*98RC*362383*RIC* - NO ONE SEEMS TO KNOW--YIKES!
in the glove it also says "series F! model 9RC. The gentlemen said, the transmission
is on the floor and original, yet the bed is wood. please help me, i am exhausted lol
  #1061
Old 04-01-2016, 09:20 PM
dmvgal
dmvgal is offline
please help me decode this vin for year model
please help me, Ive tried for 5 days to determine is this ford pick up is a 1949 or 1950
*98RC*362383*RIC* IN THE GLOVE-BOX NOT AFFIXED THERE IS A LABEL WITH THE
VIN ABOVE MINUS THE *RIC* THAT SAYS SERIES F1 MODEL 9RC.
PLEASE HELP WHICH YEAR IS THIS PICK UP, THE TRANSMISSION IS NOT ON THE COLUMN AND THE BED IS WOOD
  #1062
Old 04-01-2016, 09:35 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
It's a 1950. The RIC is not part of the VIN, it's the code for Richmond, CA assembly plant. The cutoff between 1949 and 1950 for the Richmond plant is right around 300,000. 362,383 is well past that. It may have been built in late spring/early summer, 1950. There are other folks who have maintained the records more closely and could get you a closer build date, if they happen to pop in and see this.
Only the light duty 3 speed transmission application received the remote, column shifter later in the year. Optional HD 3 speeds and 4 speeds all used the floor shift. All we can tell from the serial number is the year (1950) engine 8R (V8) F1 model (C) and the consecutive unit number.
Hope this helps.
  #1063
Old 04-02-2016, 01:24 AM
harleymsn's Avatar
harleymsn
What we can tell you for sure is that the Patent plate and the Rating plate match. Keep in mind that these are easily and often removed and switched. Now if you check the passenger side frame rail, near the motor mount and find the same serial number stamped in the frame, you have a correct truck.
  #1064
Old 04-02-2016, 08:40 AM
bradevans
bradevans is offline
bradevans is starting off with a positive reputation.
My guess is that this is an early 1950
Hi:
My guess is that this is an early 1950. From my recollection the 1949 cut off at around 250000 (98RC250001) is an early 1950
I believe they all had metal beds originally if Im not mistaken. Most aftermarket beds are wood as it is a far easier and better looking install. I put aftermarket metal beds in my last 3 truck builds
Thanks
Brad
  #1065
Old 04-16-2016, 11:14 AM
chrislynn5
chrislynn5 is offline
chrislynn5 is starting off with a positive reputation.
Originally Posted by chrislynn5 View Post
Here's the pic. From what I can tell this truck title history all had 87HT29396 on them. And if someone was going to forge the stamp, I'd hope they'd either match the title or do a better job Anyone seen this format before. I've read on other sites that the VIN could be on the driver's side and the format's could be different. Thanx.
well I was just today able to find the transmission stamp VIN under a lot of paint and it does match. It has an HT in it. I guess they weren't careful in the plant on the stampings....
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
