1948-1960: 1949/1950 VIN # Cut off - Page 52 - Ford Truck Enthusiasts Forums
  #766
Old 10-28-2011, 09:21 PM
brain75's Avatar
brain75
brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
walt, as you can see they used a star with a circle in the center on the firewall tag, and a "normal" star and double headed arrow on the frame... take it for what it is worth, another thing to throw out there is cops don't like to see "removable" tags - i.e. RIVET in your firewall tag instead of nuts/bolts/screws, that's the way Henry did it too. Base on all 20 pages here and the pix included therein you can make a really authentic looking tag/stamp. If you get the cab off, and find a stamp might take a pix with today's newspaper or have the fuzz examine it.
Walt, as you can see from mine and 20 other pages of pix, they weren't super perfect, and almost illegible at times. you can make yours as pretty as you want or as rough as you want, but "too" perfect might raise the fuzz's eyebrows... smudge a little grease and paint em half over :P
[edit]
Walt, I just went back and re-read... you say your firewall tag exists but is painted over... mine was painted with UNDERBODY rubberized coating - that nasty black stuff.
I managed to dredge mine out without completely removing the plant box, etc by very carefully using a cotton ball and brake fluid to remove the first 1/8" of paint, then rubbing alcohol and a cotton ball to remove the last 0.02" , if you have patience you might save the whole plate and not remove any of the lowest level (original) paint.. that old paint is TOUGH, and it took my scrubbing decently... if you are very slow and methodical you might get your firewall tag back without removal and reproduction.
  #767
Old 10-29-2011, 12:21 AM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
There is no vin/serial number under the cab on this series trucks.
Early Fords supposedly did (pre-40)
I bought a new data plate (firewall tag) from Sac Vintage and stamped it as bryan suggested. Attached with new push rivets that came with it. All the paint was gone from the original, but the numbers were still legible so I left the old one in place and put the new one right beside it. Ford used 1's on the data tag - see brain75's picture
And YES, use I instead of 1 on the frame stamping.
Bryan, you've got it figured out.
That 7HA 6050 is the pn for the head. V8 heads are 6049 and 6050
  #768
Old 10-29-2011, 12:43 AM
52 Merc's Avatar
52 Merc
52 Merc is online now
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Tim, it is true the earlier Fords did have more than one frame vin stamp location. Here's a diagram from Vanpelts site that I can attest to its correctness. It is also correct for more than the stated years in the image too.
  #769
Old 10-29-2011, 06:10 PM
mtflat
mtflat is offline
Wayne I agree, but I have never had my hands on one so my info is from the books. I would guess early ford trucks (pickups at least) had the same stampings as the cars because they used the same frame up until the 1942 pickup trucks got their own frame and open driveline.
  #770
Old 10-30-2011, 12:22 AM
52 Merc's Avatar
52 Merc
In my lifetime I have worked on several (at least a dozen or so) Ford cars and trucks from the 35-41 era, and they all had the triple stamping as shown in the diagram. Model A's have a vin stamp on a crossmember (iirc, over the rear axle), and I can't remember how many places the 32-34's were stamped along the frame rail, but they're there, too. That's all I know.
  #771
Old 11-19-2011, 06:24 PM
walt460
walt460 is offline
walt460 is gaining momentum as a positive member of FTE.walt460 is gaining momentum as a positive member of FTE.
OK, tonight I just bought another 1949 F1 pickup. It is a basket-case sitting in a field in PA, pretty rusty, but it is a flathead V8 with what appears to be a floor shifter original trans. The flathead has been replaced, apprears to be a 254 Merc motor.
Serial number is one the title is 98RC343229. Buy the time we got the hood open, it was too dark to read the numbers/letters on the cowl, or the serial number tag on the firewall.
  #772
Old 11-19-2011, 06:45 PM
Doc's Avatar
Doc
Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
That vin number is well within the 1950 range. 1950 F1 with an orginal flathead 8.
  #773
Old 11-19-2011, 09:50 PM
walt460
walt460 is offline
Doc,
Thanks for the info. Seller claimed it was a 1949, but his PA title, issued in 1957, just states that it is a Ford Truck, no model year. It was his farm truck, he put the Merc motor in it back in the 60's, when the driveshaft broke he just parked it.
Walt
  #774
Old 11-19-2011, 10:11 PM
52 Merc's Avatar
52 Merc
Congratulations on your new truck, Walt. It will be interesting to see if the title matches the underhood/firewall tag or glove box tag if you have one. There might also be 2 or 3 letters after the serial number on the firewall tag, which would identify the assembly plant. That code may also be stamped on the firewall. Let us know what you find.
  #775
Old 11-19-2011, 11:07 PM
walt460
walt460 is offline
Wayne,
Thanks! No glove box tag as the glove box door is missing, but the cowl tag is on the firewall. I will post those numbers as well as the cab date code info as soon as I get it home and cleaned off.
The seller provided a bill of sale stating that it is a 1949, so it will be interesting to see what the state of PA puts on the new title. I am not sure they can tell from the serial number that it is a 1950 since the 1949 and 1950 F-1s all stated with the 98RC.
I will keep you all posted.
  #776
Old 11-20-2011, 05:56 AM
Doc's Avatar
Doc
Doc is offline
Yeah keep us posted. If you can get the seller to do it, I would definitely ask him to write out a bill of sale for 1950. But if not, I wouldn't fret too much because, you're right, nobody at the local DMV is gonna be able to know the difference. Heck that very question is why the guys started this thread several years ago. To give you an idea, off the top of my head, my 49 F1 is 98RC24xxxx and my 50 F1 is 98RC 324xxx as best I can remember. And don't let anybody tell you that it HAS to be a 49 because it had a floor shifter. Quite a few 50's (including mine) had floor shifters. Only the LATE 50's had column shifters.
  #777
Old 11-20-2011, 12:44 PM
52 Merc's Avatar
52 Merc
Just to clarify the shifter thing, it was only the light duty 3 speed that got the remote shifter, sometime during the 1950 model year. The heavy duty 3 and all the 4 speeds were still floor shifted.
  #778
Old 11-20-2011, 06:10 PM
ct50f1's Avatar
ct50f1
ct50f1 is offline
ct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to behold
Although the changeover to column shifter probably happened at different times depending on the assembly plant, my truck (97HC312907 / DAH37) built in Dallas, TX on 8/8/50 came with a light duty floor shift.
  #779
Old 11-20-2011, 08:13 PM
mtflat
mtflat is offline
Keep in mind Ford was using the calendar year as model year for these trucks at this point, so your Aug truck was near mid-year.
  #780
Old 11-21-2011, 07:23 AM
ct50f1's Avatar
ct50f1
ct50f1 is offline
I didn't realize that. Good point. I was thinking that August was fairly late in the production run for 1950.
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
