1948-1960: 1949/1950 VIN # Cut off
  #676
Old 02-07-2011, 03:42 PM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Originally Posted by 4tl8ford View Post
This Panel Truck was an ex-US Army National Guard from PA
1 - Year truck is registered as (or believed to be) 1951
2 - VIN # (The whole thing including the 98RC, 98RD, etc.)-F1R1EG27392
3 - Bed - Raised Panel or flat panel- Panel Truck
4 - Is this the original bed
5 - Transmission- 3spd Light Duty
6 - Column shift or floor shift- Column
7 - # stamped into the firewall if you have one.- None
Vehicle beyond repair - scrapped
yessir Dick it was a 51. The numbers say:
F1 halfton
R 239 V8
1 1951
EG Edgewater NJ assembly plant
27382 serial number assigned to the truck
  #677
Old 02-07-2011, 05:25 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
1 - Year truck is registered as (or believed to be) 1949
2 - VIN # (The whole thing) Frame - 98RC179143
Pattent plate - 98RC179143 DAL
3 - Bed - Raised Panel or flat panel - Raised
4 - Is this the original bed - Believe so
5 - Transmission - Gone
7 - # stamped into the firewall if you have one.- somethings there but haven't figured it out yet...
  #678
Old 02-07-2011, 09:07 PM
mtflat
mtflat is offline
Yes, it's an early 49. V8 halfton built in Dallas Serial number 179143
If you find letters or numbers on the firewall, please post again
Interesting it's a column shift. I didn't think they had column shifts before mid-50.
Thanks
  #679
Old 02-07-2011, 09:15 PM
Moe Craig's Avatar
Moe Craig
Thanks
I was shocked also about the shifter column too but it was probably someones upgrade. I will post the stamps in the firewall once I figure out what they are...
  #680
Old 02-11-2011, 07:40 PM
CrazyDog66's Avatar
CrazyDog66
CrazyDog66 is offline
CrazyDog66 is starting off with a positive reputation.
Here is my F1
1 1949
2. 97HC 279708
3. Raised Bed
4. Original bed
5. PO said 3 spd
but it is a 4 spd
6. Floor shift
7. Firewall stamp RH FI 20C7630
I titled it today and I am the 3rd owner
  #681
Old 02-11-2011, 08:14 PM
mtflat
mtflat is offline
Thanks. Late 49 or early 50 half-ton six cyl. Depends on state in which it was originally titled. It could have been registered as either. Model year designation switch at that time was calendar year, Jan 1.
firewall:
RH Richmond CA plant
F1 (Ford used the letter I for the number 1)
20C March 20 assembly date
7630 vehicle down the line
  #682
Old 02-18-2011, 10:03 AM
auggie1
auggie1 is offline
auggie1 is starting off with a positive reputation.
Truck vehicle numbers (we think of them as VIN's, though they weren't called that during this time period) are located on a metal plate on the left side door post. If that is missing the number should also be repeated on the frame near the front spring hanger as shown below in the cleaned area. Sometimes this has been difficult to locate as it may be further back on the frame and may be faint. The vehicle number is the serial number for the truck and can be useful for vehicle registration as well as determine the type of truck and location of build. Serial numbers are listed at the bottom of this page.
<table border="0" cellpadding="0" cellspacing="0" width="138"><col width="138"><tbody><tr height="20"> <td class="xl65" style="height: 15pt; width: 104pt;" height="20" width="138">Antique</td> </tr></tbody></table>
  #683
Old 02-18-2011, 02:32 PM
mtflat
mtflat is offline
Hi Auggie, welcome to FTE. Since this post is specific to 48-50 serial numbers, your info in only partially correct. What you described is true for 53 and later, but not prior to that year. Read thru the posts and you'll see the differences.
I couldn't find anything relating to vehicle serial numbers on the page you linked. If we can be of any help in your searches, let me know.
Tim
  #684
Old 03-18-2011, 04:54 PM
49fordpickumup's Avatar
49fordpickumup
49fordpickumup is offline
49fordpickumup is gaining momentum as a positive member of FTE.
My latest for the records:
1949 F-1 226 Engine
97HC231205
3 KC11H300
Black paint all over/floor shifter/ one wiper/ raised bed design
title,frame/data plate numbers match
Additional info: on the firewall above the wiring hole to the cab is the number D300 in yellow letters. Also above the data plate on the firewall the number 299 in white letters.
Purchased from granddaughter of orignal owner who lived in Iowa.
The tool tray is in very good condition, as is the jack. Last tags attached were 1958. chuck
  #685
Old 03-18-2011, 05:24 PM
mtflat
mtflat is offline
1949 F-1 226 Engine
97HC231205
3 KC11H300
Thanks for adding it to the list. You know everything the serial number tells. The firewall stamping says it was black (3) built at the KC MO assembly plant on 11 August and vehicle 300 down the line.
Less is known about the painted stenciled numbers on the firewall. Often the the stenciling shows a calendar date such as 8-11-49, but there are almost as many exceptions as there are trucks.
Last plated in 1958! It has to be like a brand new truck - I'm sure a bunch of guys here will be jealous.....
  #686
Old 03-18-2011, 08:37 PM
49fordpickumup
I wish it was in great condition, but it must have been a farm truck and spent time parked outdoors after 1958. It has its share of rust. chuck
  #687
Old 03-21-2011, 07:42 PM
Robin Buie
Robin Buie is offline
Robin Buie is starting off with a positive reputation.
Another Vin question (sorry)
I think i have figured out most of the info in the vin but i dont quite get if it is a 1950 0r a 49? Also, i cant seem to figure out the punched code on the cowel?
This is what i have:
serial: 98rc374020*lb (the * im not understanding)
Stamped on Cowel: LB FN (long beach?? i guess but FN? im not sure)
The 374020 (49 or 50????)
Thanks in advance for your help!
Cheers
Robin
ps First time here GREAT FORUM!!!!!!
  #688
Old 03-21-2011, 08:03 PM
bluestang65's Avatar
bluestang65
bluestang65 is offline
bluestang65 is starting off with a positive reputation.
Hey guys, I'm working with a 49/50 truck. It's titled as a 50.
VIN on firewall 98RD359315 KC
Firewall 4KC2C3280
Glove Box door VIN followed by WBD
I'm interested in where it was built and is it for sure a 50 model? As KC keeps popping up it would lead me to believe it was built in Kansas City, but I didn't think that plant was open in 1950. Anyone have any insight?
  #689
Old 03-21-2011, 08:12 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
1950 serial numbers were a continuation of the '49 numbers, so all of them start with 9. Tim, AKA mtflat has the decode info you're looking for. He'll be along shortly.
  #690
Old 03-21-2011, 09:08 PM
mtflat
mtflat is offline
Cheers
Robin
Hi Robin, welcome! The asterisk in the serial number is just a spacer - doesn't mean anything. Some plants used it, most didn't.
LB is Long Beach as you suspected. You might take a closer look at the cowl and see if there are any faint stampings between the letters. I don't have many LB serial #'s with firewall stampings but the ones I have all follow the standard pattern of: paint code, plant, date and vehicle down the line.
Something like 2 LB 15F N
So there should be a letter or number in front of the LB and another number in front of the F. The N could be part of the line number. If you find more please let me know.
What color was your truck originally?
374020 is definitely a 50 - which is why we started this thread. The split between 49 and 50 is somewhere between 280,000 and 300,000 as near as I can tell. Because of the variations in registration processes I don't know if we can ever come closer.
Have fun around here - Tim
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
