1948-1960: 1949/1950 VIN # Cut off
  #661
Old 11-30-2010, 10:45 AM
iwanaflattie
iwanaflattie is offline
iwanaflattie has a very good reputation on FTE.iwanaflattie has a very good reputation on FTE.iwanaflattie has a very good reputation on FTE.
pursuit of vikings kicks my a**...i am waiting for amon to come to vegas....any way i am 60 miles away from home hopefully aaa can hook me up they are nicer,,,we should talk on my thread before i make the 49 50 guys mad....thanks 49/50 guys
  #662
Old 12-01-2010, 03:11 PM
hellfirejim's Avatar
hellfirejim
hellfirejim is offline
hellfirejim is starting off with a positive reputation.
My truck [dark sider] was sold to me as a 1950 F2. The Vin number is 98RD401614 which matches the glove box plate.
I take it as a 49/50 truck
8 cyl
F2
unit number 401614
I am just curious as it is already titled in my state.
jim
  #663
Old 12-01-2010, 03:26 PM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
8 cyl
F2
unit number 401614
jim
It's a solid 1950 F2 Jim. You have the other bits and pieces correct. Thanks for posting it.
The break between 49 and 50 is what we've been trying to establish with all this. The dividing point appears to be somewhere between 280,000 and 300,000.
We can't get closer than that due to:
1. incorrect reporting by some guys on ebay who see the 9 and assume it must mean 49.
2. All states title differently. Back then a truck wasn't processed thru the system of some states until it was sold, so a dealership could have an early 49 that didn't sell until late 1950 and it would be titled as a 50....even tho it had an early 49 serial number.
  #664
Old 12-02-2010, 05:07 PM
mike_hth
mike_hth is offline
mike_hth is starting off with a positive reputation.
1950 f-1
vin 98RC-327752 HP
bed not orignal late model 70 step side
trans not original c-6
looking for number on firewall
  #665
Old 12-03-2010, 03:36 PM
mtflat
mtflat is offline
Hi Mike, let us know if you find a number on the firewall.
You know the basics - it used to have a flathead V8 and was produced in Highland Park Michigan so it's a long way from home. If you want any other info, let me know.
  #666
Old 01-24-2011, 08:05 PM
tazcliff's Avatar
tazcliff
tazcliff is offline
tazcliff is starting off with a positive reputation.
Early 1950 missing glove box plate
has the early bed on it, but also came with a late 50 bed. Still have to identify engine it is a flathead 8 but I don't think the oil pan is correct (has a removable plate in the bottom of it.) and there is another flathead motor in pieces in the garage. Also had a late 50 bed that came with it.
98RC300272 (has 2 letters after the vin, will have to post those later)
  #667
Old 01-24-2011, 09:36 PM
mtflat
mtflat is offline
Sounds like it is the correct engine - the truck pan has a round cleanout that allows access to the pickup screen without taking the pan off. Only trucks had that - car pans don't.
Check your firewall for a build code.
  #668
Old 01-24-2011, 11:06 PM
tazcliff's Avatar
tazcliff
tazcliff is offline
OK cool I just hadn't seen the clean out in any material I have researched yet, thanks
  #669
Old 01-24-2011, 11:38 PM
mtflat
mtflat is offline
This website from the flathead forum might be interesting to you. Scroll down about half-way and you'll see the oil pan selections. It's a pdf file so it might take a bit to load.
http://www.flatheadv8.org/bellhousing.pdf
  #670
Old 02-02-2011, 10:41 AM
segeorge982's Avatar
segeorge982
segeorge982 is offline
segeorge982 is starting off with a positive reputation.
1949 F-1, Vin on the plate is 97HC270174
Firewall stamp(to the left of the 6V box) as best i can tell is P2NFC B3378
  #671
Old 02-02-2011, 11:10 AM
mtflat
mtflat is offline
The serial number (vin) tells you most of what you know. 1949 226 six cyl half-ton
270174 is the serial number.
Please re-check the firewall. I think it should be P 2 NR ?(6)B 3378
P was a prefix used only by the Norfolk assembly plant
2 is Vermillion Red
NR Norfolk plant - no similar plants ended in F
date code - your 'C' should be a number, the B is February production
3378 is plant code for vehicle down the line
Hope this helps
Tim
  #672
Old 02-02-2011, 11:49 AM
segeorge982
Could be a 6, hard to tell as its not very deep. Thanks for the information.
  #673
Old 02-07-2011, 10:06 AM
mtflat
mtflat is offline
Just a test to see where this shows up.
  #674
Old 02-07-2011, 11:51 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
This Panel Truck was an ex-US Army National Guard from PA
1 - Year truck is registered as (or believed to be) 1951
2 - VIN # (The whole thing including the 98RC, 98RD, etc.)-F1R1EG27392
3 - Bed - Raised Panel or flat panel- Panel Truck
4 - Is this the original bed
5 - Transmission- 3spd Light Duty
6 - Column shift or floor shift- Column
7 - # stamped into the firewall if you have one.- None
Vehicle beyond repair - scrapped
  #675
Old 02-07-2011, 01:17 PM
Ravenheart's Avatar
Ravenheart
Ravenheart is offline
Ravenheart is gaining momentum as a positive member of FTE.
You just can't save them all.
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
